  • 24V Cummins Basic Diagnostics
       (1 review)
    Use this article to diagnose driveability problems existing when a hard Diagnostic Trouble Code (DTC) is not present.
    Engine Difficult To Start Or Will Not Start
    (Exhaust Smokes While Cranking)
    • Check for low fuel level.
    • Check for low battery voltage.
    • Check for plugged fuel filter.
    • Check for poor quality or improper grade of fuel.
    • Check fuel tank venting.
    • Check for low fuel pressure.
    • Check for air in fuel system.
    • Check for fuel lift pump malfunction.
    • Check for fuel inlet restriction.
    • Check for kinked or restricted fuel line.
    • Check for kinked or restricted fuel return passage or fuel return line.
    • Check for incorrect injectors.
    • Check for incorrect injector shim thickness.
    • Check for injector malfunction.
    • Check for fuel connector leaking fuel.
    • Check for engine speed sensor and/or circuit malfunction.
    • Check for moisture in harness connectors or corroded terminals.
    • Check for internal engine damage.
    • Check for air intake restriction.
    • Check for exhaust restriction.
    • Check for fuel inlet temperature too high.
    • Check valve lash adjustments.
    • Check for ignition switch output voltage low and/or open.
    • Check starting accessories for cold weather such as engine block heaters or fuel heaters (if equipped).
    • Check fuel pump overflow valve.
    • Check for low engine cranking speed.
    • Check for electrical noise.
    (No Exhaust Smoke While Cranking)
    • Check for fuel injection pump supply voltage open or low voltage.
    • Check for kinked or restricted fuel inlet line.
    • Check for Sentry Key Immobilizer Module (SKIM) issues.
    • Check for ignition switch supply voltage low or open.
    • Check fuel injection pump.
    • Check ECM.
    Engine Surges At Low Or High Idle
    • Check for fuel tank venting malfunction.
    • Check for restricted fuel inlet.
    • Check for kinked or restricted fuel return line.
    • Check for malfunctioning injectors.
    • Check for leaking fuel connection.
    • Check for faulty fuel injection pump.
    • Check for malfunctioning or out of calibration accelerator pedal.
    • Check for damaged vibration damper.
    • Check for vehicle speed sensor and/or circuit malfunction.
    • Check for incorrect transmission clutch operation.
    • Check for dragging brakes.
    • Check for transmission malfunction.
    • Check for cooling fan cycle time malfunction.
    • Check for turbocharger malfunction.
    • Check for Bus communication malfunction.
    • Check for electrical interference (noise).
    • Check for excessive load at idle.
    • Check for incorrect or malfunctioning clutch.
    Engine Surges Under Load Or Operation Range
    Excessive Black Smoke
    • Check for dirty or plugged air filter.
    • Check for restricted/leaking air intake system.
    • Check for DTCs set or intermittent DTC malfunctions.
    • Check for ECM or PCM not calibrated properly.
    • Check for exhaust system restriction greater than specification.
    • Check for poor fuel quality.
    • Check for fuel injection pump malfunction.
    • Check for fuel injector malfunction or leak.
    • Check for fuel return system restriction.
    • Check for intake manifold restriction.
    • Check for manifold air pressure (boost) sensor circuit malfunction.
    • Check for raw fuel inside intake manifold.
    • Check for turbocharger air intake restriction.
    • Check turbocharger for excessive carbon build-up on compressor wheel and/or diffuser vanes, wheel
      clearance out of specification or damage
    Excessive Blue Exhaust Smoke
    • Check for air intake system restriction.
    • Check for air leak in intake between turbocharger and intake manifold.
    • Check for restricted exhaust.
    • Check for restricted turbocharger drain tube.
    • Check for plugged crankcase ventilation.
    • Check for worn or defective valve stems, guides or seals.
    • Check for improperly gapped, worn or broken piston rings.
    • Check for excessive cylinder bore wear.
    • Check for cylinder damage.
    • Check for piston damage.
    • Check for turbocharger failure.
    Excessive White Exhaust Smoke
    • Check for coolant leak into combustion chamber.
    • Check for block heater malfunction in cold weather.
    • Check for engine coolant temperature sensor malfunction.
    • Check for ECM not calibrated properly.
    • Check for clogged or defective fuel filter.
    • Check for fuel heater or fuel heater temperature sensor malfunction.
    • Check for malfunctioning or loose fuel injector.
    • Fuel injector restricted or blocked fuel injection or supply lines.
    • Check for fuel transfer pump malfunction.
    • Check for Intake/exhaust valves not adjusted properly (tight).
    • Check for intake manifold heaters or intake manifold air temperature sensor malfunction.
    User Feedback
    Join the conversation
    You can post now and register later. If you have an account, sign in now to post with your account.
    Note: Your post will require moderator approval before it will be visible.
    Guest
    Dieselfuture
       1 of 1 member found this review helpful 1 / 1 member
    So much good information
