  • cummins 24v/Valve seal/spring/valve replacement 24v head
       (0 reviews)
    CUMMINSDIESELPWR
    Below is a video of replacing the valve seals on a 24 valve cummins engine.
    first get a valve compression tool that is for the 24v head.
    remove injector hold down bolt
    bolt base of tool to the injector hold down bolt holes snug is fine
    place top of tool on springs centering over valve stems
    with the greased nut, tighten tool down until all the valve stem keepers are retrievable
    many times the valve seat will stick to the keepers and will need to be broken loose with a socket and hammer to free them (see in video)
    pull keepers keys (2 halves) with a magnet and place on a template for each valve (do not mix any parts to other valves)
    loosen tool and remove plate
    take springs and keeper seats off and place in there designated holder
    with pliers, grip and twist and pull the old seals off
    clean seal seats as there will be crud under them from oil and soot
    yellow seals are intake14mm deepwell socket to drive these
    green seals are exhaust 13mm deepwell socket to drive these
    replace yellow for yellow and green for green after cleaning seal seats on head
    place each spring and keeper seats back to original positions and ensure they are seated in the head properly (not sitting on a machined lip)
    then pull on each valve stem to make sure they are all the way up
    place tool plate back on and centered
    place nut back on the tool and torque down to where you are able to place the keepers back in
    once keepers are put into the "keeper pocket" push the valve down a little to get the keepers to grab the valve stem (may need to elevate the head a bit to get clearance to do this)
    when all keepers are preset, untorque the tool and watch the springs to ensure they grab the keepers and they sit in the pocket properly
    when pressure is off remove top of tool and remove bottom of tool
    re-install injector hold down bolt with a dab of BLUE loctite
    inspect all 4 valves for proper re-installation
    done
    if valves are to be replaced or different springs are to be replaced it is the same steps outlined above. for more details please watch video below.
    http://youtu.be/BpSH_BzKq6k
    User Feedback
Advertisements and Ad Blockers
Mopar1973Man.Com uses the income from advertisers to pay the bills on the website. Please whitelist your ad blockers for Mopar1973Man.Com this will allow advertisements to display on our pages but allows you to still block ads on the other websites you visit.
I will whitelist Mopar1973Man.Com
