Starter Contacts Disconnect and isolate negative cables of both batteries. Raise and support vehicle. Pull back protective rubber boot from solenoid battery terminal far enough to access and remove nut securing battery positive cable wire harness connector eyelet to solenoid battery terminal stud (Fig. 10). Remove nut securing battery positive cable wire harness solenoid connector eyelet to solenoid terminal stud.(17mm) Remove battery positive cable wire harne
