  • High Volume Funnel
       (0 reviews)
    High Volume Funnel
     super-tech-brake-fluid.jpg.ab4783cb3c24dneck-sizes.jpg.b115327d0130a98fd504592c6
    Get a bottle of brake fluid from Wal-Mart. Use the brake fluid for your truck. Change out your brake fluid. Take notice there are two different sized necks you want the larger of the two if possible. The small neck won't work.
     cutting-the-bottle.jpg.1540f4167424d16c6bottom-removed.jpg.495bc0d7c7f1727c67cc3
    Now just cut the bottom off the bottle carefully.  Basically this is what you should have. A bottle with the bottom gone and the cap removed.
    Now it screws right into the valve cover on a 24 Valve Cummins. I've not tested it on other trucks but it works for me...
     funnel-in-use.jpg.56ab71da5a5bbb94a3b16d
    User Feedback
