  • PCM - Powertrain Control Module
       (1 review)
    PCM
    Operation
    Two different control modules are used: The Powertrain Control Module (PCM), and the Engine Control Module (ECM). The ECM controls the fuel system. The PCM does not control the fuel system. The PCM’s main function is to control: the vehicle charging system, speed control system, transmission, air conditioning system and certain bussed messages. The PCM can adapt its programming to meet changing operating conditions. The PCM receives input signals from various switches and sensors. Based on these inputs, the PCM regulates various engine and vehicle operations through different system components. These components are referred to as PCM Outputs. The sensors and switches that provide inputs to the PCM are considere PCM Input
    Inputs
    • A/C request (if equipped with factory A/C)
    • A/C select (if equipped with factory A/C)
    • Accelerator Pedal Position Sensor (APPS) output from ECM
    • Auto shutdown (ASD) relay sense
    • Battery temperature sensor
    • Battery voltage
    • Brake switch
    • CCD bus (+) circuits
    • CCD bus (-) circuits
    • Crankshaft Position Sensor (CKP) output from ECM
    • Data link connection for DRB scan tool
    • Fuel level sensor
    • Generator (battery voltage) output
    • Ignition sense
    • Output shaft speed sensor
    • Overdrive/override switch
    • Park/neutral switch (auto. trans. only)
    • Power ground
    • Sensor return
    • Signal ground
    • Speed control resume switch
    • Speed control set switch
    • Speed control on/off switch
    • Transmission governor pressure sensor
    • Transmission temperature sensor
    • Vehicle speed inputs from ABS or RWAL system
    Outputs
    After inputs are received by the PCM, certain sensors, switches and components are controlled or regulated by the PCM. These are considered PCM Outputs. These outputs are for:
    • A/C clutch relay and A/C clutch
    • CCD bus (+/-) circuits for: speedometer, voltmeter, fuel gauge, oil pressure gauge/lamp, engine temp. gauge and
    • speed control warn. lamp
    • Five volt sensor supply
    • Generator field driver (-)
    • Generator field driver (+)
    • Generator lamp (if equipped)
    • Malfunction indicator lamp (Check engine lamp)
    • Overdrive warning lamp (if equipped)
    • Speed control vacuum solenoid
    • Speed control vent solenoid
    • Tachometer (if equipped)
    • Transmission convertor clutch circuit
    • Transmission 3–4 shift solenoid
    • Transmission relay
    • Transmission temperature lamp (if equipped)
    • Transmission variable force solenoid (governor sol.)
    Wiring Diagrams
    pcm1.jpg.b1b909905d5ae012cf9db70d1534a72
    pcm2.jpg.d172fc7dae6e90742719878f8eca614
    pcm3.jpg.4247a31ab1922f04e989d4ec5c8ab28
    User Feedback
    Dieselfuture
       1 of 1 member found this review helpful 1 / 1 member
    Always informative
    Link to review
