  • Welcome To Mopar1973Man.Com
    We can see that your guest and been lurking about. When you register on the Mopar1973Man.Com site you'll be able to interact with all the other members. This is the most friendliest Cummins forum you'll ever join. Take the time right now and  REGISTER  on the Mopar1973Man.Com this will open up many more options and functions on the website. Everyone is very friendly and helpful just ask questions and everyone will help you out the best they can.
Sign in to follow this
Smarty Support
Smarty Transmission Tuning and More
Good afternoon!
We've published a new release for the Smarty Touch:
A milestone :  FREE complete 68Rfe transmission tuning.
This update addresses the 2010 to 2016 trucks.
Complete means:
1) Raised line pressure in all Forward gears AND during the shifts.
2) Increased shift firmness for less slip in the clutches.
3) Changed shift points at WOT in all gears @ 3000 RPM.
4) 6th gear unlock and downshift to avoid the massive torque and make the transmission last longer.
In addition to the transmission tuning a few other things are changing also.
1) Revised timing for less combustion noise.
2) Revised rail pressure.  The actual rail pressure follows now more precisely the desired rail pressure.
    This becomes most noticeable under WOT and / or with aftermarket injectors.
3) Several DTC codes have been addressed.
4) A few things have changed in the Touch's menus.
5) For customer care : a new firmware which now writes a .txt file onto the SD card with all the information's about:
    Tuning settings / OTF settings / Firmware version / Tuning software version / Bat voltage and the like.
    Read that file from the SD card and send it to us.  It will help us tremendously helping you, our valued customers
 You will find this free update here:
http://smartyresource.net/forum/showthread.php?950-Trans-Tuning-and-more-Smarty-Touch-Update-12-4-15&p=4712#post4712
Also if you have an 11 or 12 C&C and are interested in being a beta test please let me know!
Thank you!
Brian
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
