Permission? Donation?
I have a quick question...well a couple. First off I've been trying to view the 2nd Gen ABS braking system info posted last week and get an error code 2F173/H. It says "you do not have permission to view this content." I wasn't sure if I was able to view this or not? 2nd I made a donation on the 2nd of December and just want to make sure that it was received. It shows everything went through fine on my end.
looks like it is across the board for all members, There are only a million different check boxes,musta missed on haha.  we will get it sorted.
Thanks for finding it!
Do you know what subforum it is supposed to be in?  the URL posted doesn't look right for what I was expecting.,
is this it?
Loooks like Mike may have moved it.
Edited by Me78569
Actual I can't move nor can I fix it per say. It a phantom thread it doesn't exist. When I submitted the file it create a thread for the file but I never set it up to create into a set forum, so it dropped into the first open forum it could. Bad part is no one can touch it. Not even a master administrator like myself. I can see it but can't even delete it.
Wow. I had to go deep into the MySQL server and manually delete that phantom thread... It's gone now...
41 minutes ago, Me78569 said:
Yea I was thinking that might be the case when you posted that screenshot.
BBHD, are you able to see what you are looking for in the Download section?  or where you just looking to read the unread item?
I was just Looking at it because it was new info. Ha always looking for new info :thumbup2:
