Defrost and floor air only.
7 hours ago, Buzzinhalfdozen said:
6 hours ago, gassernomore said:
Did you reattach the selector tubes on the drivers side of the unit? Has like 5 different tubes for the selector switch.
Found it. Main vacuum line broke. I replaced it and rerouted it through the driver side of the firewall after I found a diagram.
On Saturday, December 19, 2015 at 8:38 AM, Mopar1973Man said:
Could you paste a link or a upload attachment for that map...
There you go. Hope that helps in the future.
Now I've run into the famous blend door coupling failure. Any ideas where to get another one.
