Ball joints
Well half way through my trip up north I have found that my Balls joints are loose again.
The moogs lasted 20K
The Danas lasted about 15k
Not really sure what to do.  I would love to just get something that lasted from the factory, but I dunno.
Thoughts on what to try?  Should I do the dana ones again?
What part # Dana's did you use?
1 hour ago, Me78569 said:
Do those work in a 2000? they actually show another for the 00-02http://www.dennysdriveshaft.com/p2077_dana_spicer_708047_ball_joint_set_for_2000_to_2002_dodge_ram.html
I see a 2000 in your sig. Were the for another truck?
Just doing a general hunt for those part number on the internet turns out scary results. There hardly anyone selling Dana Spicer parts. Even common place like RockAuto or NAPA doesn't even list them.
Now Amazon got a few...
http://www.amazon.com/Yukon-YSPBJ-016-Joint-Dodge-Differential/dp/B00EHN7KXQ/ref=sr_1_2?ie=UTF8&qid=1451099098&sr=8-2&keywords=DANA+SPICER+708047
Quote
This replaces Spicer part number 708047
Obsolete part number? Maybe that's why there is so few of them on the web...
So how much play is too much, when having front axle on jack stands and putting pry bar under tire moving up and down? Mine move between 1/32 and 16th on both sides. And do you do unjoints and seals at same time or just replace wats bad. What's the life expectancy on axle seals and u joints?
Up and down movement is NORMAL regardless of what the alignment shop tells you. it's the side to side play that is the issue.
i've been looking at several options for new ball joints. XRF was recommended. and rebestose something or others was also recommended.
So is it the heat treatment or the alloy mixture that makes them better ball joints? I imagine some are just mild steel.
 Is there Any thoughts about bringing the new ones to a forge and have them treated/ change the metalurgey? I don't know.... someone might understand this process to make them good BJ's.
