Radiator drain plug fix.
It would be nice if you could change the valve to a brass ball valve somehow with the right fitting to adapt to the O ring female fit on the radiator. But then I am a dreamer...... someday I might try that with some plumbing fittings.
After fixing it, I haven't touched it since.  I use a chunk of tubing and siphon it out the top.
And yeah, I just grabbed a random O-ring that looked about right.
Silicone spray lube will work for getting it freed up.
It a twist, pull out, then twist again... To drain normally.
At that point once its drained out just twist a little till it stops then pull out gently.
I've done this twice now repairing drain plugs one on a 2nd Gen and one on a 4th Gen. So technically the article is should be relocated to "General Cummins" being does work for 2nd Gen, 3rd Gen and  4th Gen.
