2003 F-650 with 24v 5.9 Cummins No start
supachaged
I was going to use the Dodge manual but was not sure if being used in a different application if the wiring was the same. I can tell you that the wires are not the same color for the engine harness on this ford as they are for the dodge. I need to run a relay in between the ecm and lift pump.
 Thank you, I will use the pinouts from the dodge manual and the diagram you gave me.
Edited by supachaged
Added info
