Factory keyless entry
Aslong as the truck has a factory key FOB it automatically has the "security system" right ? Which basically means truck wont start if been locked with key FOB and unlocked with key correct ?
My 99 01.5 and current 02 all had a factory key FOB.I thought they were to just unlock and lock the doors when i had my 1st truck. Noticed there is a red light under the rearview on my 02. I assume flashes once armed ?
My 99 if you locked it with the FOB and unlocked the door with the key horn would go off. The 01.5 didnt do this or the 04.5 i had. Haven't tried with the current 02.
29 minutes ago, dripley said:
My 02 has key less entry but no security system. That I believe was an option.
Interesting so yours all it does is unlock and lock the doors ? I will look at my build sheet to see what it says.
Edit: Just looked and its listed as two different options not even one after another on my buildsheet.
remote keyless entry
security Alarm.
Edited by moparguy55
security Alarm.
I only have the keyless entry.
