Grid heater relay solenoids and P1291.....opinions
Found it.....
The ground cable from the grid element to the manifold had a bad connection and was causing an intermittent ground issue.
Here's what I found.  Because I dont think I could have found this little cable anywhere local and the corrosion was on the exposed end, I shortened it and re-crimped it and sealed it.
The wire was sticking out of the rubber and exposed about 1/4".  I pried open the connector and cleaned up the wiring.  Then pulled the rubber cover as far back as I could and shoved the connector back on as far as I could and re-crimped it.  Then covered it with shrink wrap and sealed it off with liquid tape.
Edited by KATOOM
