Abs pump running nonstop
Today everything was fine until suddenly the abs lights pop up... when I stopped I heard something running and it was the booster pump motor. Even with the key off it was going 90 to nothing. I unplugged it and it stops. Plugged back in still has same issue. What could it be any ideas?
Thanks but in readings it's been ground wires and possible bad abs modules just looking for the least expensive first... I went on a hunch last time and spent $4500 when it was bad batteries and a loose ground... not saying you're wrong just want to be sure I'm on the right track
Module masters is the right one
Stay away from myairbags.com
If your grounds are ok .......which i never heard of causing this issue ..... don't see another way to check .......
I just know that's an issue on our trucks that they can fix.
You could try calling them I believe it's about $100 fix and they warranty the fix
