Quadzilla V2 Custom Tunes
Me78569
MPG will be all using the current hardware just a new gauges and using just some internal calculations done based on the fueling commmand and how big your injectors are lol.
Edited by Me78569
Will it still be 4 small gauges on the outside of a large one? Or will their be more slots to watch more gauges on the home screen?
I also did something to my truck this weekend ? normally when I have a hard shift or if I punch it while cruising it will let out a puff of black smoke but now it will let out grey/white smoke ?. Still runs great and starts up every time so I’m a little dumbfounded on this so I’m just gunna run my mpg tune for a while and get that dialed in before I dig into this issue
you can select different gauge sets, swipe left or right to change the screen.
Is that on the current display or after the update? If it’s on their right now I’ve been missing out ?‍♂️
2 minutes ago, Me78569 said:
right meow.
are you sure your smoke is just not more like haze now?   I would spend some more time dialing in your tune.
Wow I feel stupid for not seeing that ??
Im using the same tune and everything. Haven’t made any changes to it but now it’s grey/white smoke. This is on my fast tune which is the only one that smokes at all under hard acceleration or hard shifts a little puff will come out but now if will just do a little cloud of grey/white so I haven’t been running that tune since or any of my higher tunes actually ?
Just swiped through all the guage set ups. This is a game changer ? glad I asked that question or I would have never known ? that just made my day!!
yea I like the main gauge in the middle and the 9 around the outside.
Might throw a little more timing in the rpm range that you are seeing the grey smoke.  Do you have studs? ( please say yes)
Nope haha, I’ve been watching it closely and am not putting a lot of timing into it for that reason. No oil in coolant and I’m not losing any coolant so I haven’t blown my gasket(knock on wood). Ordering some arp 2000’s before I get into more extreme tunes for that reason
you grey smoke might clear up with more timing, or less timing lolol.    Can you isolate a rpm range where you have this smoke?
Haven’t been paying attention to the rpm range, but it’s under hard acceleration where it should be black smoke but is coming out as grey which I don’t know why because I haven’t changed the tune. So I’m just gunna run the mpg tune til I get studs then I’ll mess with it
Sounds good. I really like how we can be so controlling of the truck. Really appriciate the work you and others have been doing.
ME The injectors you have on your truck those are about 75hp right?  Also do you have head studs? Are your tunes pretty safe to run on a 50hp, so pump'd, no other improvement 01 HO?
Ive been reading however I am not 100% confident on the timing portion yet so I am leary of messing with things I don't totally understand yet.
14 minutes ago, Me78569 said:
I have ~200 hp region injectors currently   I have head studs.
My tunes will not be suited for your truck it will be a dog.  You will want to run Mikes tunes or the tunes I put out for mild injectors.
How do you like those 200hp? I’ve got a buddy selling some 200’s and I’m currently running stocks
I very much like them.   You need to pull fueling down a lot at idle to clean them up, but you get a lot more meat under the curve.
I would verify what brand and configuration they are.  ETC are they 7 x .012 or 6 x .013 or vco or sac what cone angle etc.  When you talk injectors that size you need to be careful to ensure they are right for your application.
Mine are 7 x .012 vco at 330 bar in an effort to make them more dd friendly.
@Youngblood24v your pump low boost scale is at 5 psi that means your wire tap will come in at that if your tps is at 20% or above. Unless you're driving in level 3 where it only uses canbus fueling, you're dumping extra fuel. You might want to up your canbus a little more to start of and maybe slightly steeper curve, and set pump low boost scale to about 14psi. And at 80mph I would think you should see about 22-23 degrees of timing. That means your rpm range timing needs to be at that or higher or it will limit your cruise timing. I hope I explained it correctly, if not I'll get corrected :wink:
Try both see how smoke is.  You want to see haze on the darker side if you got wot from a light.  See which one you like better
I would guess stock though.  The mid might be a little weak.  There's also a75 tow tune.
Edited by Me78569
Thanks.  I did some comparison of the injector numbers and figured that those mid tunes were for 100hp plus trucks which put my 50hp right in the middle.
Once again thanks for wverything your doing.  I can't wait to get back home and start learning.
No prob, let me know what you think,  I don't have a good grasp on how 50 hp fuel compared to stock so it is hard for me to build a tune for them. I am guessing you can get away with a good bit of fuel without running into smoke issues.
