Im pretty sure its a bearing failure its making a squalling noise with excessive grinding in 5th and 6th the the shifter will about vibrate ur arm off, I'm running 7qt oil, it doesn't have coolers, I've only pulled one 6k load and don't put a load on 6th gear if a can't cruise above 1800rpm on flat strait roads I don't use 6th
