Be aware that the blocks and plates set the angle of the rear axle.  The angle of the dangle needs to be the same at each end for the U joint to work properly or you will have vibration.  If the machine shop makes them square, you might have to do some shimming.
You can check it with a level & protractor or a smartphone and the TREMEC company's app.  Google Tremec toolbox app.
3 hours ago, 01cummins6 said:
I have a 2001 dodge ram 3500 2wd. What's the best way to lower the rear?
Let the air out of the rear tires. :cool:
3 minutes ago, CSM said:
Brakes squeaking?  Apply grease!
I am full of awesome tech tips!
Tried that on the 5th wheel. The brakes did not squeak bid but my arse made bit of grinding noise. Thanks for the tip.
4 minutes ago, CSM said:
Levity!  Just having some fun.
Just having fun too. I did happen though. Blew grease thru the seal on 2 of the wheels and it got on the shoes. That was an adventuresome trip with brakes greased.
Where can you get new u bolts
http://www.zenithspring.com/index.html
This is where I get U bolts from, they will make any custom size you want. You'll need to measure the width of your leaf spring, length and diameter of the U bolt. I'm assuming you have a 9/16" diameter bolt but the easiest way to check is see what size wrench fits over the threaded portion of the bolt.
