trreed's upgrade thread
1 hour ago, Me78569 said:
So it runs with a swapped psg?
I have always wondered.  You now you have an ho pump with a so computer?  Call it the cold rod pump?
Was this post meant for Tyler's build thread? Otherwise I'm just getting confused! Something about that Colorado air!
:ahhh:
No, this pump went on Tyler's truck, for the sole purpose of getting him home.  I'm still getting a pump through DAP, which should show up today.  Tyler swapped the PSG's in about 5 minutes and his truck runs great now, except for a stumble at idle.  Must be a side effect of a cold rod pump!
Edited by trreed
I wonder how much I could sell this cold rod pump for?? It's got a custom lope tune at idle :lmao:
@trreed I don't see any updated turbo pics....
Edited by TFaoro
New pump showed up tonight!  However, it won't be going into the truck right away due to a dry, cracked tappet cover gasket. (thanks to @TFaoro, whose favorite past time is to show me what's wrong with my truck lol).  But, it is a good time to do this repair, if the parts store could ever find the gasket in their stock....
Made some progress on the VP install today, mostly concerning the tappet cover gasket and a stock filter housing delete.  @TFaoro also helped run an extra coolant line to monitor coolant pressure in the cylinder head.  The VP did go in the truck, but it is not tightened down yet, and I am waiting for the black paint to dry on the injection lines.  Pictures of the VP and black injection lines will follow tomorrow, but all I have for now is the tapped cover gasket.  Yes, that is yellow paint in the lifter valley, and I am not sure why it is there... Also I am aware my engine is dirty.... (pictures loaded backwards)IMG_3216.JPG.269887834f2dde91e15b1bc75ba12728.JPG
Edited by trreed
