bad connection in the plug somewhere. You could pull it apart spray some cleaner in there, then plug it and un plug it a few times and see if that helps. Then put some dielctric grease on it and see what happens.
Most likely the plug itself is worn out. I would consider replacing the plug before it melts. I've seen this happen a few times where the plug get weak connection and the plug melts to the headlight bulb socket. Then its a royal pain in the rear to get out and also you possibly lose the headlight bulb too.
