  • Welcome To Mopar1973Man.Com
    We can see that your guest and been lurking about. When you register on the Mopar1973Man.Com site you'll be able to interact with all the other members. This is the most friendliest Cummins forum you'll ever join. Take the time right now and  REGISTER  on the Mopar1973Man.Com this will open up many more options and functions on the website. Everyone is very friendly and helpful just ask questions and everyone will help you out the best they can.
Me78569 RaceTune
View File
This is my race tune.  It has a much more agressive take off which results in heavy haze / smoke at high Throttle input.  at WOT you will get no less than %25 wiretap.
Keep in mind Altitude for this tune is ~7000' so it will not be suited to a similar truck at sea level, you will need to add ~%10-14 canbus across the board for sea level.
Share this post
Link to post
It does with my own tunes, just wanted to try and download someone else's tune to try out and that's as far as i can get. It will download it but then i can't open it, I'm sure I'm not doing something right.
Share this post
Link to post
humm.  I just opened it from my downloads folder on the phone.  Try starting the app, hitting hte home button > apps > downloads > click the tune.
Share this post
Link to post
RaceTune.json
Ones downloaded I see this59837f9f56f07_2017-08-0314_54_30.png.4189fe1b6b02f00e7cb3bd9c1ac16ff4.png
And then if I try to open it it says no app can perform this action
Other phone just did same thing.
Edited by Dieselfuture
Share this post
Link to post
hmm. I did it on my S5 without issue, and on my S8. You might need to make sure that you have the latest version of the app downloaded. Somehow, the .json file association needs to include the iQuad app. You might have to go into the file associations and delete whatever the default association is for .json so that you can choose the iQuad app to be associated with that file.
figure out what app is opening it by default. Then go to settings -> Apps, find the app and tap "clear defaults". the next time you open it you will have the choice to view it in the iQuad app or the other to choose from.
On the iPhone, you have to use email, you can't just download it or look at it, you have to download it, then email it yourself then it will open in the app.
  • Thanks 2
Share this post
Link to post
Ok just tried it again and it worked this time, did everything same, I hate technology.
Correction, I couldn't load it from downloads directly but when I opened new tab and scrolled down all downloads were shown there and it worked from there.
Share this post
Link to post
I have purchased 2 different times and when I press download file it doesn’t do anything at all and I don’t receive any file what do I need to do to receive the files I have payed for?
Share this post
Link to post
So I got the tunes downloaded to my phone and opened in the app but not all parameter have a value, is that how the tunes are setup or is that an issue with the download?
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
