The best riding 2001 dually possible
Ok so if I am going to tear into the suspension on my 350k mile truck, I want to improve it as much as possible.. In my old OBS ford that mean at least doing an RSk, etc....  Is there anything I can do for this truck for tremendous improvement?  It wouldn't bother me if it made it sit a little lower (modern height 4x4 dually trucks sit pretty low now)
Thoughts?
Thoughts?
For tremendous improvement, NO, not on a 2nd gen. Everything on the front end of my truck is new, and it's still a boob jiggler. The ride doesn't compare to my 1/2 ton with independent front suspension.
On 6/30/2017 at 1:28 AM, TFaoro said:
@jlbayes might be able to help on this.
If you really want it to ride well though I think you're going to end up spending a bunch of $$$$
This^. A 3rd gen track bar will help, new bushings, shocks, coil springs, will help...bumpy roads are bumpy roads in a dodge. Best thing I did to smooth out vibrations was centramatics for the wheels.
Just googled these. Do you think they really worked or had an added positive affect?
They definitely balanced out my tires. I had some decent tire cupping from my shock bushings settling/coming loose up front, and even after balancing again the truck had decent shake at highway speeds. Centramatics took care of that.
