That stuff easy to fix but the guy should have head examined. He has no spring centering cap on it. Instead he has the shock absorber holding the spring only it not centered. I can see possible bent/ damaged shocks... Man... . Sway bar end links are supposed to be longer.
The guy may be hiding till you gone so you can't talk with him.
Edited by JAG1
Man, I sure don't miss the rust buckets that come out of the north....  The plow truck on the family farm in MN ('95 Ram 1500) is impossible to work on due to rust.  All the salt they use up there makes for a not fun time working on things..
