  • Welcome To Mopar1973Man.Com
    We can see that your guest and been lurking about. When you register on the Mopar1973Man.Com site you'll be able to interact with all the other members. This is the most friendliest Cummins forum you'll ever join. Take the time right now and  REGISTER  on the Mopar1973Man.Com this will open up many more options and functions on the website. Everyone is very friendly and helpful just ask questions and everyone will help you out the best they can.
Sign in to follow this
WiFi Calling without WiFi Call enabled cellphone
Ok Gang...
Just learned a new trick today and want to share it. Being now my cellphone now works at home and can make phone calls without cell service. All I need is WiFi signal and the phone works. So now I've got 2 cell numbers that work.
Actual Cell: (208) 315-1470
WiFi: (208) 740-1747
https://thedroidguy.com/2017/08/receive-wi-fi-calls-google-hangouts-free-without-sim-card-1063470
This web page explains how to do it but I will mention the uncheck box in the Google Voice is not present but you have to remove the linked phone number to make it work. So sitting here at home I can call my WiFi Cell number and it rings like normal.
Why am I doing this? The LG G5 cell phone I bought is UNLOCKED no carrier brand. Not to mention LG in their wisdom decided to omit to WiFi calling feature. So between using Google Voice and Google Hangouts I've managed to create a free phone number and now have free WiFi calling without cell service.
Share this post
Link to post
I use WIFI calling with the same number all the time on Project fi.
If I am on wifi the service works across the wifi otherwise it chooses between t mobile, Sprint,  and Us cellular depending on what serivce is faster.
The neat part is I can start in my house walk out get in my truck and drive away while on the phone and magic happens to keep the call active.
Share this post
Link to post
It is a software and carrier issue, not a hardware issue.  As carriers move to using volte rather than lte for the service you will see more and more wifi calling.
The device itself doesn't care what method of connection it is using, just that it has connection.  That's the beauty of voip.
Edited by Me78569
Share this post
Link to post
that's my point.  As technology advances we are going to see less and less of a what carrier / brand.
I am excited you got it working these types of things force forward the acceptance of the network to allow this type of thing.
Share this post
Link to post
+1 on Project Fi, great coverage, only reason I switched from Fi to T-mobile is because my wife uses too much data and it's cheaper to have T-mobile's 2 person plan at $100 a month with no data cap. But T-mobile has calling over WiFi using your same number which is nice. @Mopar1973Man are you running Fi? If it's an unlocked variant i'd hop on over to XDA-Developers.com and see if someone has developed a method to unlock the bootloader so you can flash a custom recovery and then flash a custom rom. That's what I've done on every phone that i've had up to my Galaxy S8+. Although i'm contemplating on switching back to my Nexus 6P. Not as fancy a screen or battery life, but the ability to change songs on my phone while im in my truck by holding the volume up or down button is amazing.
Edited by Cronus577
Share this post
Link to post
Just switch from TracFone to Verizon. I'm just got tired of the crappy service and always paying way more for data. I burn more data than I do minutes. All the local towers are Verizon.
Already done...
https://forum.xda-developers.com/lg-g5/help/unlocked-lg-g5-rs988-wifi-calling-t3672640
Then I called LG but they couldn't help me. All they could suggest is buy another phone. Crap. M73M just replaced my phone 3-4 months ago.
Share this post
Link to post
Found this is another thread.
Dial *#546368#*850# in the phone app.
Select SVC menu.
Select VoWifi.
Try a system restart after enabling if the option is not visible.
Since it's an unlocked version it might not have the option visible since it's just factory unlocked and a PSP hasn't uploaded their own crummy bootloader.
Share this post
Link to post
Yep Fi is good so long as you are not a heavy data user when on cell only.
I firmly believe that Fi is hte future for how plans will work.
Right now I have coverage on every network directly or via roaming.
Tmoible
Sprint
Us cellural - which roams on verzion.  No extra charge.
and wifi
the down fall is price per gb, which makes it a bad plan for some.  However my average bill is $21 per month and my wifes is $23 per month.
Share this post
Link to post
Select SVC menu.
Select VoWifi.
Enable Wifi calling.
Already been there... Tried again just for fun. The code for my phone is close... Dial *#546368#*988#. (Change the last 3 digits to the model number of your LG phone). Now when you do that and go for the VoWiFi option set it to ON or 1 then reboot and go back it set for OFF or ZERO again. Still no option for WiFi calling.
So the only way is to replace the phone or use a WiFi Calling App. My method is a hack but it works.
Share this post
Link to post
Dang technology, at least the phone is yours and Verizon can't sneak their bootloader into it. Any chance you know a place that can test an ECM? Buddy told me last weekend while I was working on the truck that the junkyard just received a automatic 2001 24v engine. Previous owner had blowby, thought it was the vp44, replaced the vp44 and it kept running bad so he pulled the vp44 and junked the block, managed to grab the injectors, fuel lines for 1/2/4, ecm and valve cover. I might go back and grab the rocker arms and push rods since I pulled one of the rockers and it was spotless, no scoring of any kind. Appears to be completely stock
Share this post
Link to post
