Quadzilla Boost Level Fueling - CAN Bus
Now for those of you looking to get your "Daily Tune" smoke-free as possible. So I'll say @Me78569 is right you want to set the Quadzilla to level 1 and use the valet mode to find your start fuel percentage. So keep rolling back till you can no longer see smoke from a heavy throttle launch. So once you got that figured out now you need to build a good fueling curve. Now change the Quadzilla to level 3. What I use for building curves is an exponential growth calculator.
http://www.rapidtables.com/calc/math/exponential-growth-calculator.htm
Enter initial value (x0): Use your value from level 0.
Enter growth/decay rate (r): Use your growth rate percentage 1-4% typically.
Enter time (t): Enter Boost Pressure number here.
Now you want to start with your starting fuel number you got from level 0 and then use that as your starting number. I suggest a growth rate of about 2-3% typically. If you use too much growth percentage you see the smoke come on mid boost so this is a sign to back down your growth percentage. I'm not saying a full -1% but maybe try like -0.1% or -0.2%.
3 hours ago, Me78569 said:
Keeping in mind that this process if for guys with larger than stock injectors.   With Stock injectors you can start your tune at %110 of so depending on how aggressive you want the tune.
I was starting at 105% and working my way up using about a 2.5% growth rate.
Our default that seems to match pretty well with what the older ADR2_1000 tune did starts at 105 and grows exponentially from there. (kind of a guess of the exponents) but here are the settings we are putting out there for default stock trucks that nearly match the ADR2_1000 feel:
0 PSI %: 105
1 PSI %: 107
2 PSI %: 109
3 PSI %: 111
4 PSI %: 113
5 PSI %: 115
6 PSI %: 118
7 PSI %:  121
8 PSI %: 124
9 PSI %: 127
10 PSI %: 130
11 PSI %: 134
12 PSI %: 138
13 PSI %: 142
14 PSI %: 146
15 PSI %: 150
16 PSI %: 150
18 PSI %: 150
20 PSI %: 150
22 PSI %: 150
24 PSI %: 150
26 PSI %: 150
28 PSI %: 150
30 PSI %: 150
