Headlight upgrades
So I got all the parts except the bullet shroud does not fit inside housing, too big around and I had to order apollo2 flat that Mike has with his d2s. My question is for high/low my harness came with brown/white wire that is not in the plug 9006 that it came with, I got to put that in and before I do it backwards any one has a picture maby, thanks.
Edit. I think I'm asking about wrong wires, as I'm looking at instructions on line it says it doesn't matter how you plug them in its only powering silinoid for hi/low. I haven't got to the plug that originally plugs into old bulb yet. Still learning....
Edit. So hi/low to get it right, need to switch white and brown in morimoto harness.
Edited by Dieselfuture
@Mopar1973Man here is what they look like, are you saying you can see where they sanded flat part even more to where there is a hole? If so I guess I can just make my bullet shrouds work, just was under impression apollo2 flat stile fits right in :ahhh:apollo_2.0_projector_retrofit_shrouds_2_1_1.jpg.f71587283790e37181f63fd9dde6ef22.jpg
Edit. Now that you said hat I think I can see a hole right through the shroud, aaaaaahhh, I think I'm going nuts.... next time will be listening to my wife and just by a complete set, NOT.... lol.
On 11/25/2017 at 8:01 PM, Marcus2000monster said:
let me know how you like yours!!
So, ..... I love mine, if you're patient you can try doing d2s if not get h1. Both will be better than anything else out there.
One thing I thought I had figured out is couple of pins that need to be switched around for high/low to work properly, whell that part works but when I turn fogs on by pulling out switch it will turn my high beam on :doh: and even by switching hi/low it will keep highs on until I push in the switch for fog lights in. @Mopar1973Man guessing need to move pins around some more? If you ever close to your plug can you take a picture of it?
On 12/2/2017 at 9:40 AM, Mopar1973Man said:
I stand corrected... Thank you for the find...
I had to cut off about a1/4" on top side to make em fit in, just to clarify for anyone else looking at apollo 2 flat shrouds. And my original bullet shrouds I was going to use were too tall and would of hit the lenses or been right up next to them.
Good to know @Dieselfuture
Sounds like you got one of the pins. I had to try a couple combos to make mine work correctly.
