Block plug boost adapter
Just a quick question. Finally getting my gauges in. Going to get my boost reading from the block plug behind the filter housing. My local hardware has the 3/4 to 1/8 bushing but only in galvanized. Wanted to make sure that was okay or if I needed to get a steel fitting.
Galvanized fitting can and will still corrode.  Galvanized would work, but I would hold out for a brass fitting.  I've seen cheap galvanized fittings that easily chips away, I would hate to see any debris from a bad fitting make its way into your engine.
7 hours ago, 015point9 said:
News flash...toilet flange bolts don't work to good in muffler clamps:whistle:
BTW, aren't you the guy that uses 4'' galv pipe and threaded couplings. for the exhaust.... I think I heard about you :lol3:
Edited by JAG1
  • Haha 2
