  • Welcome To Mopar1973Man.Com
    We can see that your guest and been lurking about. When you register on the Mopar1973Man.Com site you'll be able to interact with all the other members. This is the most friendliest Cummins forum you'll ever join. Take the time right now and  REGISTER  on the Mopar1973Man.Com this will open up many more options and functions on the website. Everyone is very friendly and helpful just ask questions and everyone will help you out the best they can.
Me78569
Large Injector Race Tune, T = OEM + timing
View File
this tune is meant for guys with 7 x .011's and bigger, that are having issues getting timing figured out.   This tune uses OEM timing + a few * of timing as rpm climb.
at 1500 you get oem + 2*
2k: oem + 3*
2.5K: oem + 4*
3k: Oem + 5*
max: oem + 6*
IT IS VERY HIGHLY RECOMMENDED TO ONLY USING THIS TIMING TUNING METHOD IF YOU CANNOT FIGURE OUT WHAT YOU TRUCK WANTS FOR TIMING.
Edited by Me78569
Share this post
Link to post
How do you achieve timing like that when everything is set to 0 (factory timing) and rpm vs timing is 12 all across.
Also have a question on canbus, if we're setting percentage of canbus per psi of boost, I know that even without any boost my canbus can change drastically.
Edited by Dieselfuture
Share this post
Link to post
The flashes within the last 6 months have a hidden function that allows you to use oem timing as the base rather than the quadzilla timing.  It is kinda like a easy timing method.  I don't like it personally but it will be easier to tune.
  • As for canbus.  We are setting % of oem canbus at a given rpm.  The oem canbus message is very dynamic depending on tps input,boost, rpm.
Share this post
Link to post
Refresh my memory. Set all timing parameters (screenshot below for reference) to zero, and then the RPM based timing turns into an offset? I kind of want to play with this when there's time.
Edit: I realized as soon as I pressed send that I could just import the tune and look at it... My bad.
Edited by kzimmer
Share this post
Link to post
Exactly, set all those to 0 then the rpm settings become an offset over oem for timing.   I think the full timing method is much better for a well rounded timing curve.
This method resuts in either or type of tune,  either you have good cruise timing or good performance timing, not both.
Share this post
Link to post
Yeah that makes sense. The ECM can still pull timing for emissions purposes which is counter productive. Still has that goofy curve with a bunch of variables that we don't care about.
Slight problem though. I downloaded the tune and it shows a 12 degree offset acrros the board instead of the 2,3,4,5,6 you have listed. This could be problematic, lol. I think that's what @Dieselfuture was getting at.
Edited by kzimmer
Share this post
Link to post
I HIGHLY recommend not using this method.   Just know that haha.  If you already have a hang of getting timing where you want it then you have no business using easy tune.
Edited by Me78569
Share this post
Link to post
Guest Salerno 5.9
How do I download on to a iPhone thanks
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Donation Goals
    Mopar1973Man Medical Bills
    If you want to donate to Michael Nelson medical bills. Any fund donated here will be directed toward the medical bills and getting them paid.
    30%
    $150.00 of $500.00 Donate Now
