  • Welcome To Mopar1973Man.Com
    We can see you lurking about Mopar1973Man.Com reading articles and reading other member's posts. Are you trying to solve a problem with your Dodge / Ram Turbo Diesel Cummins? We have lots of helpful members and staff on the Mopar1973Man.Com and are willing to give guidance on how to fix or improve your truck. Sorry, we are a subscription website now. We are not corporate owned like many of the other websites out there. Like Cummins Forum (VerticalScope Inc.). Mopar1973Man.Com is entirely privately owned and operated since 2004. Your subscription funds goes towards server maintenance and software maintenance. We happen to be one of the most friendliest and helpful websites  for Cummins Owners in the world. Come join us and register and then pick a subscription plan.
A.C. ripple percentages
outlaw7
The question has been raised as to what an acceptable ripple percentage is. Depemding on who you talk to you get everything from .1v all the way up to 2.0v
and from where I'm standing even .1v ripple is enough to upset a computer that likes 5vdc for operations. so this post is going to be kind of dualistic 1 I'm asking for members to post what thy are reading from theyre trucks and 2 anyone that hgas a specification for an alternator to post them here. the following are the parameters to follow
1 of course is automatic as you post your id
2 the year make model and mileage of the tested vehicle
 type of life it has if you commute on weekdays and mud on weekends I need to know or if you don't shut it off for 3 days straight from runnin3000 miles I want to know you get the idea
3 type age and shape of your batteries as well as specs and don't say square shape duhhhh I mean are they pristine or do they look like a pair of double a batts found in a ten year old flashlight in a swamp
4 and this is important please follow exactly or your results will be suspect. you wi be taking readings in a scientific manner which is extremely important for correlation later
   information necessary at start of test
   the meter must be a digital variety with good leads set to vac in a lower range so that any ripple will be recorded take your time and double check your readings before recording them please and use the right hand battery Driverside for grounding don't worry about ground loss as the purpose is to get a good ripple cross section
   A. temeperature in farrenheit at time of test.recorded both at start and conclusion
   B. the truck needs to be warmed up for a sufficient time so as to attain normal operating temperature for your truck
   C. you will be taking two separate readings at  different rpms with and without device loading
   D. unloaded test no accessories of any kind not fired up via the key run cycle
   E. loaded test to include full headlights in hibeam mode, heater set on high heat/highfan/ through the vent
   test point A is at the stud of the alternator output not.... I REPEAT NOT the nut the cable or any other point . I will dissertate on this subject in a later article please just take it as gospel
   test point B will be at the stud of the power distribution box again this is important for continuity in the study
   est point C will be at the tow connector at back of vehicle youll be testing the run light circuit which on a four pole flat will be the only one with juice on a seven pole the aux power the             center will also work but please specify which one you took
   F. you will be testing at each of these points at the following rpm ranges
       range 1  idle and record your rpms via tach
       range 2 1800 rpm or nominal cruise speed youll need someone to hold it right there for each point
       range 3 2200 rpm hi output limit though most will start to fall off a touch at this point
   G. one last thing is a loss test this is to be conducted at idle and its the control portion you will attach the black probe to ground with the meter set to dc and the engine at idle
        take the following readings at the exact points  A at the alternator output stud
        B at the nut on the output stud
        c at the furthest point on the cable connector to the alternator output
        D at the furthest point on the connector to the power distribution block( make sure its the alternator feed )
        E at the nut of the power distribution block
        F at the stud of the power distribution block
record all dat and report it in the following format
________________________________________________________________________________________________________________________________________________________
Outlaw 7
2001 dodge 3500 series 6 c&c
354,627 miles used primarily for hotshotting until 5 years ago at 334k then a daily driver average 500 miles per month if driven
original alternator, old batteries lh (pass side ) 750cca deep cycle Walmart rh 800cca deep cycle Duracell both in good shape clean ends oem cabling new clamps
temp 56 degrees F
rpm              idle750      1800       2200
point a           .09vac    .14vac      .13vac
point b           .08vac    .13vac      .12vac
point c           .05vac    .1vac         .09vac
loss
point a          13.5vdc
point b          13.4vdc
point c           13.4vdc
point d           13.2vdc
point e           13.2 vdc
point f            13.1vdc
all my data is fake as my dually issans ecm and pcm till next week some time ill post my actuals then
remember this is volunteer only please and thank you but if your going to take the time to do this do it right and accurately and take pride in knowing you are benifiting the greater good of the cause you never know helpers might just get rewarded as well in the end thank you again guys I look forward to seeing your posts this is outlaw7 over n out......
Link to post
ok I bit the bullet yesterday and order a cheaper hankok ???? 8ch usb oscilloscope which apparently ships from china as it wont be in until 2nd week of February if I'm lucky but it claims some seriously awesome capabilities including can buss diagnosis etc so well see... I mainly wanted it for my r&d on the ripple filter project but I can think of like a thousand other things ill use it for ill start a thread on it once I get it and put it to use
Link to post
for those of you that are curious about the last portion of the test , this article should clear up any questions
I'm creating a form that you can print out to make this easier itll be up soon
Link to post
Archived
