I bought a 3 gauge package from Vulcan and it included a pod that sits on the dash. I still have a 3 pod on the pillar from  glow shift. I like the one on the dash and going to swap the 3 pod for two pod I got with the Banks kit and add an oil pressure gauge.. The 2 lower gauges dont function since the Banks crapped out.DSC01380.JPG.4d39edcdd4b2bcbe506729d0b327cf49.JPGDSC01382.JPG.01804a74feb1fe57c68b93dc68bbee2e.JPG
I run EV1 gauges as well. I did have a leak once, but it was due to the compression fitting not the gauge. It was just a drip. I smelled it long before it made a puddle and just turned it off under the hood at the needle valve. I now run braided steel hose up to the gauge with -4an fittings on it. A smaller version of what all the other fuel line is run with so I highly doubt it will give me problems, especially not at >20psi. I did the boost in this as well.
Like others have said, the EV2s have bells and whistles. Its your preference. Mechanicals can be more of a pain to install. I do think the incandescent bulbs match the truck better.
Also, my EV1 FP has developed a bit of a buzz that kind comes and goes.
9 minutes ago, dripley said:
I drilled a small hole in the bottom of the pod with the fp gauge so i would know if it leaked and it did. Had to re tighten the line.
haha I did the same thing! I actually smell the fuel before it even found its way out the hole. It was just coating my gauge when I pulled it.
  • Haha 1
