When I bought my truck it had a Isspro Fuel pressure gauge mounted in the left pillar. I installed a Fass150 and Edge Juice with attitude.
2years later, I would like to hook up the Isspro gauge again...it's just sitting there and I think its cool when it works.
My question is, whats the best way to make this happen? Cut the line before/after the current one and run a completely separate setup? Will this cause any issues?
Below is a pic of my current set up. Thanks for any help!!
ohh thats a cool fitting, I didn't even know they made those haha.. I guess, you could use the ISSPRO as your daily check and use the digital EJA to make sure your ISSPRO is still accurate from time to time.
however, myself, if I had that config (WJA and a ISSPRO) I would run the ISSPRO post filter and the EJA pre filter. I mean, why not have "more" data.
or just remove the EJA gauge hookup to clean things up :)
