Timing Reduct Scaling
So this is a fairly typical issue with hot tunes.   the ecm is overracting at cruise.  It is not a timing issue, keep fueling at %100 or near %100 in your tune until you are above your typically cruising psi.
no fix on stock injectors other than start and hold at 100% until ~5 psi or so.  or just make hte tune less aggressive in that 0-5psi area,
Also make sure you are not using wiretap at cruise.  that will make hte issue worse
Edited by Me78569
Ok so I can adjust my 0-5 to 100% and then from there on ramp up quickly and that should lessen the cruise hesitation?
No wiretap right now but will be soon. Currently at
tps pump min 20%
Min pump tap fuel 0%
pump low boost scale 5psi
boost scaling 40
Should I adjust those? I’m trying to get to a point where I have a tow tune and a DD/scoot tune and that’s it lol
