  • Welcome Guest To Mopar1973Man.Com
    We are a Dodge Ram Cummins Turbo Diesel forum. We are very friendly and helpful group of Dodge Ram Cummins owners. We will try to keep your truck running the best we can and provide information for diagnostics, repairs and even guide you on the best replacement parts to use.
    Registration is free. Registering on the site will provide access to many more things like...
    • Contribute to the Forum being able to ask questions and get support for your Dodge Ram Cummins.
    • Contribute to Article Database adding your ideas and suggestions.
    • Classified Ads posted by the members. Post up your used parts and vehicles.
    • Member Garage where you can proudly display your vehicles and modifications that you have done to them.
    • Download files, documents, and Quadzilla Adrenaline tunes for your truck.
    • 911 Support Network. We've got a group of members will to aid you if your truck breaks down on the road.
Posted (edited)
I've got to ask @Dynamic what has to happen for the transmission to downshift out of overdrive to 3rd gear?
I'm wanting the truck to hold road speed with the cruise control (vacuum cruise) and it will hit a hill or grade and the speed fades way back like -10 MPH from set speed then it downshifts and struggles to make up the lost speed as it climbs.
Now the TV cable if I add a bit of pull to the TV cable it makes the shift rather overly firm (bang). A neutral position is a good firm shift. Slight bit of slack shifts mellows out a bit more. This doesn't seem to make any impact on the downshift while in cruise.
This leads to the fact the cruise module might not be pulling enough to get a downshift or what? That why I want to ask the transmission guru! :)
Share this post
Link to post
I know with my truck, if I’m cruising along in 4th locked, it takes almost %100 throttle to get it to drop into 3rd locked. Might be the same with the 96 but not shred just figured I’d chime in with my experience.
Share this post
Link to post
Like I've posted in my Back to Spark Plug thread I'm going to change up the tires from 235/85 R16 to 245/75 R16 to aid in the low-end response. This size change will add 26 revs per mile more and the tire is about 1 inch smaller. Then the face will be 10mm wider. Should give me a nice boost to the gear ratio.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
