Choosing Gauge for 47RE
100 - 280, covers it well. In the cold weather you will find it takes a while to register to a 100, on the high side you shouldn’t see anything near 280, generally the trans temp stays around the engine tremp, a little higher when towing or the steep grades, I have mine probed on the cooler line outlet, right on the outlet port, but pan probe is just as efficient just depends who you ask, main thing is your monitoring it
