Problem solved
Need a little help here as I am stumped. I just pulled the Vac/steering pump as a unit and fixed the oil leak with new seals and a new power steering pump. After everything was back in and fluids were topped off I test drove it and right away the ABS and parking brake light came on. I checked the vac line and its connected. My vent control works great so I know the system has vacuum. Test drove it and power steering works and brake pedal feels good but a panic stop locks up the rear brakes (no abs function). What am I missing?
Truck is a 2001 2500 Cummins 4x4 extended cab.
found a wheel sensor plug was not properly connected.
Thx in advance.
Edited by SavageConcepts
I am curious about this statement. Does the ABS system rely on vacuum pressure in some way? As long as I have owned the truck, the ABS has been non-functioning. The ABS module is currently disconnected as when you plug in the pig-tail there is a motor that runs constantly. I have had many vacuum related issues over the years, so i am wondering if there could be a vacuum related problem. I assume that my issue is a bad control board, just never have done anything about it.
Neither. Only relies on the 3 speed sensors if braking is normal then all 3 sensors will slow together. But like in a panic stop on slick road one wheel will slide then the speed on that wheel will be greatly lower so the ABS system back pumps the pedal prevent any further pressure applied till the speeds equalize again.
You need to send in your ABS module to Module Masters in Moscow, ID they can rebuild that module and fix that problem.
Its been on my list for awhile now, just havent gotten it done yet. i think i have his site saved around here somewhere.
