15 hours ago, 975speed said:
It does it only when barely moving could it be a u joint
A vehicle with a bad u joint will also have a vibration on hard acceleration and/or with a heavy load.   Sometimes a bad u joint will cause a vibration at freeway speed.
Can you have someone ride in the bed of the truck and listen while you drive in a parking lot at low speed doing figure eights?
