brake bleeders
Does anyone regularly use a power bleeder here?  Whether vacuum or pressure?  Pro's/Cons?  I am thinking I want a vacuum style as I have multiple cars and a pressure style would require many caps.  I don't always have a helper when working on the cars and its time for fluid flush on the truck and my car.
Thank you
Neither. I use a mayo jar and a piece of vinyl tubing for years. Cost nothing and works every time. It can be done solo even.
Basically get an old glass mayo jar and a piece of vinyl tubing that fits over the bleeder nipple. Poke a hole in the jar lid and slip enough tubing into the jar so the tube can reach the bottom. Now add just enough brake fluid to bare cover the tubing end. Now open the bleeder screw, hook up the tubing. Jump in the driver's seat and pump the brake pedal. Since the tube end is submerged in fluid the brake system can't draw air in. Since its easier for the reservoir to supply the fluid than to draw it back from the jar it always flows in a normal fashion. When you empty your jar always leave a bit of old fluid in the bottom. Always remember to check your reservoir after about 5 to 6 pedal cycles you'll be able to move a large amount of fluid quickly. This method works from everything from ATVs to full-size pickups no problems.
dodge-rear-axle-disc.jpg.1812d8588feab18
Now I've had a vacuum bleeder but hated that stupid thing. No matter what you set up for nipples or tubing the bleeder screw always leaked air in past the threads. The only way I was capable of making the vacuum bleeder work was using thick axle grease on the threads of the bleeder screws to seal the threads. This will work on any vehicle but the same issue happens the vacuum typically leaks past the bleeder screw threads.
Pressure bleeders are nice but not for the price tag and the requirement of all the special caps you need for every single different reservoir cap design out there. Too much of a PITA and cost to have everything you need to use it. So you limited on the vehicle you can use it on if for example a friend wants you to work in his Ford and you've got a Dodge cap sorry it won't work. So you end up buy more and more adapters just to fit everything that might come your way.
Awesome idea! And cheap alternative to boot. Thanks!
We used to do our VW bugs this way with beer bottle instead of mayonaise jar, did all 4 wheels at once :-) :-) :-)  We would use coat hangers made to stay in the jar and hang them too (kinda spring loaded diamond shape hanger forced into the bottle)
Edited by portlandareae28
Good idea, another reason to have a beer before work, or 4
  • Haha 1
Looks like I'll need to buy a case of bottles instead of cans for the next brake flush.:lmao:
I use the jar method as well. I have a vac bleeder but don't use it anymore for the reasons mentioned above. Always sucking air through the threads.
You might have to, if you want glass mayonnaise jars you are going to have to go to an antique store :-)
