Alternator & PCM failure
Believe this repair just saved me the same headache you just had, put in the 5amp inline fuse and 140amp breaker. Haven't started truck in 3 weeks (out of country for work) the alternator I rebuilt this summer was squeaking somewhat. 10 mins later is squeaking its heart out loud n proud. End result is it tripped the breaker, diode is shot and the rear bearing was toast. Rear cover was hot.
Here I thought the squeaking would stop after it ran some. Boy was I wrong.
Share this post
Link to post
5 minutes ago, Mopar1973Man said:
Did it blow the field fuse too? I'm curious...
I'm glad the breaker worked out for you and kept the truck from being damaged. At least my misfortune became your savings.
Nope fuse was good. I checked that also.
And breaker did its job thankfully. but we've all been there as the one who finds out the bad stuff first. Like when the Dana 80 checked out on me few years back. Passenger side hub gets Less oil.
Share this post
Link to post
Just keep thinking, guy is got to get lucky once in awhile. Good thing you did the mod when you did.
I also did mine, it sure is nice having a piece of mind now.
One thing though, are used a fuse holder that has an LED or some sort of the light that lights up when fuse blows, got it at Walmart. I like the idea I'm just not sure if that light will let current through. Any thoughts anyone?
Share this post
Link to post
Yes it does. It uses the unpowered device as a ground plane to light the LED so there is current flow but very small.
Share this post
Link to post
Do you think it would be enough to hurt anything
Share this post
Link to post
L.E.D.  Stands for Light Emitting Diode.  It only emits light when power is applied across the L.E.D. in the correct direction, and it usually has a 470 ohm resistor in series with the diode (if my memory still works).  That limits the Current through the LED.  So to answer your question no.  No damage downstream.
Michael
Edited by int3man
Share this post
Link to post
Milliamps worth. Be aware wiring or device failure can cause the LED to not light even though the fuse blew. I've seen this few times.
Share this post
Link to post
1 hour ago, Marcus2000monster said:
Is they’re a wiring diagram for this circuit breaker?
Just like a fuse. Just wire it close to the battery. This gets lugs and wired in like the fuse on the alternator charge line.
Share this post
Link to post
So were wiring the breaker and the fuse both into the blue alternator lead?
Share this post
Link to post
No.
Blue wire gets a normal ATC 5 amp fuse and holder.
Black large gauge wire (charge wire) gets the 150 Amp breaker.
Share this post
Link to post
This is just another of the great threads we see around Mopar1973Mans website and makes me glad to be a part of helping support this great community of helpful Cummins enthusiasts
One question..... Mike your picture of the 5 amp fuse holder shows a heavier gauge wire coming out both sides of the fuse holder, heavier than the blue wire itself, would this wire help to absorb enough heat to cause the fuse to burn a bit late in its ability to protect the PCM? ?
Share this post
Link to post
Negative, the extra copper won't absorb energy. All of that current still has to flow through the fuse element, and the fuse element will still heat up the same regardless of conductor size. So you're safe no matter what you use.
Edited by kzimmer
Removed a rogue 'z'
Share this post
Link to post
No. The gauge of wire doesn't matter. My solar panels are hook up on 2 ought cable and have only an 20 fuse. Fuse is a designed weak link so the fuse fails before devices, wiring, or fire is created. Hence why opt for the 5 amp and not the 7.5 amp.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
