New ecm, no power at all
Hey everyone, new to the forum i have a 99 eclb. I put a new ecm in after signs of a failed ecm, while I was waiting on the new one I pulled the alternator out to test it to avoid the bad diode problem. So I figured id do the mod w-t wrote about with the regrounds and new alternator power wire and what not. Well cut to I finshed it all up put the new ecm in and hooked the batterys up and i got nothing? No interior lights,headlights and no power at all. I had batterys tested and they were good. Cleaned all of my grounds again made sure everything was hooked up .checked over the wiring a few times im clueless now, im not good at electrical diagnostics, any idea of where to start?  Thanks for the advice
Make sure all ECM harness connectors are plugged in all the way.
I'm gunna see if i can find a friend to help cause i know zero about electrical. I second guessed my self to even do the new ground change cause I really dont know much about electrical. From what I read from your simplified write up, you break apart the loom and cut the ground where it meets the 4 wire, ground those to the gear case and run a ground off the neg terminal to the same spot. Then run the alt power wire to the pass side pos terminal.?
I ohm tested the fuses in the pdc all were good
Lol knowing my self it was something stupid i did or forgot, i appreciate it you saved me a ton of aggravation.
Now my only issue to solve is the lift pump isn't cycling before startup. It cycled one time for the first key up with the new ecm then nothing.
Oh i have been there just like you. Electrical is not my strong point by any means. I just knew it had to be simple. Thats why I enjoyed being a giant for that brief moment. I had pause about that wire when I did the mod. I did replace it with a new one from the parts house.
 I do know that the ECM controls that prime of the lift pump. So I am thinking that is an ECM problem. Who rebuilt your ECM
4 minutes ago, Boondockboost said:
Lol, I bought a new unit from an aftermarket company witch is proly a no no but i got it from all computer resources in florida
Give these folks a shot. Handling my PCM problem quite well.
https://mopar1973man.com/forum/196-auto-computer-specialist/
I'll tag @Auto Computer Specialist to get them involved.
Aftermarket is your only choice these days. I went thru this about 9 years ago. Getting help was almost non existant at the time. My experience was painful at the least.
 The above article has some known good rebuilders. I would star with contacting the rebuilder and and letting them know about the problem.
 Does the truck start ok? Have you tried to start it?
I just noticed that is the wrong article.
Edited by dripley
  • Haha 1
