Fuel mileage sucks! Please help!
8 hours ago, Scottfunk said:
Is this realistic? It's not that I can't afford to pay for pop testing but I can't afford to have my truck down and I can't afford to drop the injectors and have a guy tell me I can pick them up thursday and then listen to some excuse about how they won't be able to get to them until next month.
I don't know about Idaho, but I did 2 day shipping on my Injectors from NJ to DAP in UT and had them back in the same week, and that included getting them re popped, flow tested, and having them ship them back.
I went through the same gambit. I had 4 injector shops tell me everything from 5 day to 2 weeks to get my injectors done, since no one stocked shims and springs etc. So I was concerned about that. But DAP had that stuff in stock and I believe that it was done in the same day and finished.
Mike may even have an injector tester set up or know of a place up that way?
Edited by pepsi71ocean
I wish. I would be pop testing my own injectors. :broke: Head gasket and this PCM project have wiped me out.
The best place I know of is in Lewiston, Idaho they do pop testing for free. Then if you next to actual pop to set then its $9 an injector.
Master Tech in Boise will pop them right in front of you for free. Mine were all sorts of bad...low pop pressure, bleed off, you name it. They are rebuilding them right now for $65 a piece, genuine Bosch parts and matched, not a bad price just bad timing. I will report back how it affects my situation.
@Marcus2000monster you might want to follow this.
Apparently they also have a one hour turnaround time when there's a shop hand available. Brand new genuine Bosch nozzles matched to 305 Bar =/- 5 Bar, "These are technically 50HP nozzles," he tells me. And I got a free T-shirt! Great experience all around.
Why do all the shops always pop them low?
Right out of the FSM.
Then within the next little bit of mileage, the pop pressure will fall a bit more after everything settles. It sure does shorten the injectors lifespan before the pressure falls off again. :shrug:
19 minutes ago, Marcus2000monster said:
Any reason not to send my oem injecotrsnin and have 90 hp vco nozzles installed and popped to 320?
You could. Nothing wrong with that...
15 minutes ago, Scottfunk said:
You might be right, I do remember hearing something about 315, maybe it was 315 =/- 5. I was so distracted by shiny new nozzles I was having a hard time concentrating.
Might want to check. Hate to see you install and have to pull them back out again.
I’m thinking I’m going to send in my oem sticks and have either 75 or 90 hp nozzles installed and popped at 320 bar. Pop pressure sound good? Should I do 75 or 90? Obviously smoke and lag is reduced with higher pop pressures but are 90s going to create egt issues? I will eventually have tuning but not for a while. @pepsi71ocean @Mopar1973Man
