Fuel mileage sucks! Please help!
5 hours ago, Marcus2000monster said:
I’m thinking I’m going to send in my oem sticks and have either 75 or 90 hp nozzles installed and popped at 320 bar. Pop pressure sound good? Should I do 75 or 90? Obviously smoke and lag is reduced with higher pop pressures but are 90s going to create egt issues? I will eventually have tuning but not for a while. @pepsi71ocean @Mopar1973Man
I'd be really interested in seeing how your truck performs. I  believe that you should be fine with that set up. 90's on a HX should be ok, unless your towing heavy.
If you do move forward I would love to see the results, because we do need more data then we have which is literally myself and two other guys.
Im going to try it. Might not be right away though.
OK @Mopar1973Man I need help. My #6 injector won't go back together. It feels like its in all the way, the keeper feels right when you bolt it down, but the tube won't seat in the side of the injector. There is evidence on the tube and the nozzle that the tube is riding low in the seat but I can't find anything wrong. I used a flathead screwdriver to make sure the old copper washer isn't stuck down there and it's not. Of course it's number 6 so I can't look down the injector bore. Check out the pictures...
I use my smart phone and turn on the light and take a video, and move the phone over the hole, and look at it.
Sometimes my injectors don't sit all the way down at first, and I lube up the Injector O rings and use the valve cover bolt to give it a love tap and she will seat. Its best to torque the crossover lines first before tigtining the lock bar on the injector top. But always rememebr to loosen the blue colored lock bars that hold the injector lines first, high pressure leaks are a ***** to diagnose, its best to avoid them in general.
10 hours ago, Marcus2000monster said:
Does anyone know how many bar the injectors drop when they settle in?
The consensus among the guys who did a few repops on their injectors for the raised injector testing saw an average of 10 bar over the first 5,000 miles or so. So while some hard starting or stalling may exist, the issues will lessen. Even for me at 320 bar the first few times the truck stalled was hard, but after a week of driving the issues went away.
Although, i still suspect I have transmission issues, so i can't say that is why I had stalling issues since the truck doesn't stall in manual 1 or reverse.
injector-exploded.jpg.4e81f2a90bd18342d3
Not much to 24V injector.
The little washer looking thing is a shim next to the body. The spring is a fairly heavy coil and rides directly on top of the shim. In all the injectors I've messed with the shim will wear over time with the pulse of the fuel pressure popping off. Between the nozzle and pintle wearing and the spring shim wearing this is where the slack is gained and the pop pressure falls. As the VCO nozzle wears the nozzle typically becomes pissy and leaky at low pop pressure like idle this why some report a strange misfire at idle with a warm engine.
On 12/22/2018 at 7:17 AM, Mopar1973Man said:
Minus 50*F off that for correct EGT's as shown by my ISSPro. The Quad is +50*F higher.
Is there a 50° difference when cold/off as well?
I drove the truck this morning and this photo came to mind, so I got on I-84 and set the cruise at 65. It puts me at ~1850 rpms. Coolant was 190°, IAT was 40°.
I'm currently running my single event 12V Tow tune, which has 14° of timing at this rpm/load. Load was around 18% and 30-36 mm3.
EGT's floated right at 600° ±25° and after 8 miles my economy was 22-23, but not enough miles to see how it holds nor enough to be fully warmed up and have temps settle to their "normal" range. (Warmed up I'll see 500-550° under the same conditions).
The truck was also cold, oil temp didn't get to operating temp until 4-5 miles onto the interstate so I was burning some extra fuel there, especially when you think about the 8 qts of 75w-90 in rear diff with minimal load to warm them up. It usually takes me 40+ miles of winter driving to see the cruise load/EGT's drop to "normal" once everything is warmed up.
So when I consider the truck wasn't fully warmed up, I'm around 1K lbs heavier, and have more parasitic drag I'd have to say they run pretty similar temps/load/economy.... but the intriguing part is the timing difference which does nothing more than highlight the differences in VP vs CR injection.
So on a VP you have to really increase the timing at lower loads since that's when the VP starts building pressure, whereas on a CR the timing is when the injector opens... big difference there!
When I am running a tune with a pilot and getting similar mpg's the EGT's are always higher, which comes from having a pilot and not being able, nor needing, to run the main with that much timing. The retarded timing means more heat out the exhaust, but the mpg's mean I still getting peak efficiency out of it. If I get much above 8° of timing with a pilot event I start to haze and lose efficiency.
Just some morning commute thoughts and such :burnout:
From bottom up is the same +50*F off. This is why I'm got the defuel limit of EGT set to 1350*F because it actually fully engaged at 1,300*F and comes on at about 1,200*F.
That screen capture was back during the summer time. Now with winter time I'm running slightly retard timing right at 19.5 to 20* at 2K.
I'm toying with running the single event tune for some towing to see how it does. If that's the case once it warms back up I'll redo my numbers.
1 hour ago, Me78569 said:
no,  Low popping injectors can only be due to the build of the injector.
12 minutes ago, dripley said:
Or how much use is on them??
So i have an intermittent miss/lope at idle hot or cold that im trying to figure if its injector or associated with the fuel leak at the back of the head that i have.
I dont believe a leaky return line can cause a miss. Loss of prime and extended starts yes.
32 minutes ago, Mopar1973Man said:
Bad injector spray pattern will cause the miss or lope.
Dam I’m not impressed that these injectors have issues with only 10k on them. I can’t decide what I should do. Funds are tight and cheapest option is repop my stock injectors for 175$ and ideally a set of brand new 75hp vco for 350$.
Have you spoken to DAP about the problem? If you want a decent kick in power and are a ways away from a tuner, get you some new RV275's. You will not be sorry. They are very good injectors and should give you a good life. Not sure what NEW 75hp injectors you are seeing on DAP's site. I have a set of their 50's, with aftermarket bodies, with 100k on them that are just now showing some weakness. The RV's are great on a stock truck or with a mild tuner.
