Flashing WTS/ ECM replacement
Went to start my 1999 2500 and the battery was dead. After charging the battery, My wait to Start light was flashing and wouldn't start. I have read a lot about this pointing to a bad ECM. I was planning on sending mine to carcomputerexchange.com. $514 for a rebuild and lifetime warranty.
I haven't pulled any codes yet. I'm going to buy an OBD2 reader tomorrow when i get off work.
My questions are...
1. Is there anything that would fry the ECM that i should check before the new one goes in?
2. Has anyone dealt with carcomputerexchange?
Also, my WTS light hasn't come on at all for about a year, but starts overtime no matter the temperature.
PS- I removed my grid heater
I've dealt with Auto Computer Specialist in Florida for my PCM failure. Excellent people. @Auto Computer Specialist
As for the AC noise you need to have the alternator bench tested for safety. If you have a quality DVM you could do it yourself following my write up. I still suggest removing the alternator and bench testing is the safest option. Then you'll need to do the W-T ground wire mod then do the PCM protection mod.
Just giving an update... replaced my alternator. I am getting ready to ship my ECM to Autocomputerspecialist in Florida. Hopefully while the ECM is getting rebuilt I will do the W-T mod and PCM protection.
I was able to start my truck about twice after i got new batteries and alternator (only when the WTS wasn't flashing)? Is that a good sign, or is that irrelevant?
Just means you hopfully don't need to do the Vp-44. I'm thinking its just the ecm. You got lucky sir.
