P0336 No Tach, Lack Of Power
1 minute ago, Mopar1973Man said:
Wire end to end should be 0 to 5 ohm max.
Wire to ground should be infinite.
Test for 5V with the key on at the sensor plug.
Then I would replace the sensor.
If still not right then I would send the ECM for testing.
I appreciate you simplifying that for me. I did those 3 things and got those results. Buddy I bought it from says he got it tested, but maybe he was told wrong. Where should I send it to get tested?
5 minutes ago, Mopar1973Man said:
@Auto Computer Specialist which happens to be a vendor here.
https://mopar1973man.com/forum/196-auto-computer-specialist/
Give them a call and let them know I sent you.
I appreciate all the help! I will definitely give them a shout today. I’ll also keep the forum updated on what I find out Incase anyone else runs across this
  • 3 weeks later...
The easiest thing to do is drop your starter and pull the CPS then with a mirror or borescope check the tone ring. I fought the same problem for a few months. It can be fixed without pulling the motor, as long as you have some patience. I'm working on a write up to detail the whole thing. Dodge no longer sells the parts but cummins has them for about $150 you will get the tone ring and 5 screws that hold it in. I have part numbers, torque specs and a tool list. Pics of the position the crank need to be for install.
