P0112 & P1693 With High Idle Switch
If I unplug the high idle harness and plug the factory wiring into the sensors I do not get any codes, plug/hook up the high idle harness I get P0112 INTAKE AIR TEMP VOLTAGE LOW & P1693 DCT DELETEDIN COMPANION JTEC MODULE. Any ideas?
wehn did you get the switch?  This is typically a bad switch, the last batch of switches ( the actual rotatary switch) has a higher rate of bad connections internal to them.
Put a support ticket in to get it warrantied.  Support@mopar1973man.com
Ok Ill put a ticket in, its only a monthm or 2 old thanks.
