Wide open throttle still
So after reading most of the forums i could find im still haveing the wide open throttle issue. I put a new APPS on it calibrated it started the truck up worked great. But if i turn the truck off and start it back up its wide open throttle again when i touch the gas then back to idle when i let off. But i can unhook the battery cable for 20 minutes or so hook it back up start the truck and it works fine. Any help or suggestions would be greatly appreciated, thanks.
I would say you have an bad ground somewhere, but then again I've been more wrong than right about such matters. Still a bad ground creates an unbalanced electrical system to where AC noise cannot be absorbed by the batteries. Most often it originates from an alternator that still shows adequate charging but is beginning to fail and thereby emits excessive AC ripple. Mopar1973Man taught me all this stuff so hang around you will see the beginnings of a good education around here.
Edited by JAG1
1 hour ago, dripley said:
It would not hurt to check the new alt out. Some fail out of the box, more than you might think. Checking grounds and general elctrical health is always a good idea.
I kinda look at it like something that always has to be done from time to time.  There are still a lot of trucks that never had any grounding connections checked/ cleaned since they came off the assembly line.
I suspect you might have a good alternator but still have a bad ground somewhere.
Edited by JAG1
Sure you aint been smoking the high altitude Oregon logs again?  AA HA HAAAAA old friend. Couldn't resist that one.:bolt:
  • Haha 2
I had to quit smokin that oddball tobacco and start a clean cut shaving program since everyone thought I was a hippy that also might smell bad if they got too close........
You need to get out west Bud.... before your too old to enjoy being around our fire with a few :cheers:
I wish I could post up an old picture of this old hippie.That was my past occupation, but I got paid for going to work everyday. I kinda liked that paycheck on weekly basis, Sure made it easier to pay the bills.
7 hours ago, JAG1 said:
CODYFARLEY, don't mind us, this is what we do around here.... Hy Jack threads ever so often.:USflag:    Please do hang around  though, as these guys have taught me a lot.
I might also add you will get your questions answered. Some answers will take longer than others though.
