Dead truck P0216
Still need to relocate the sensor off the pump. Need at least 5 feet of 1/8" air brake tubing. Pulsations of the pump will eventually kill the sensor. Pump is upstream of the filter on both AirDog and FASS.
Inlet -> Water Seperator -> Pump -> Fuel Filter -> Outlet.
So, should the sensor be plumbed into the main fuel line upstream of the pump, or plumbed off the pressure port and at the end of the 5 feet of air brake tubing?
Mopar1973man on too many meds...... from surgery..... It goes like this.......
Fuel tank---- water seperating filter-----lift pump-----factory filter-------fuel pressure 'T' and needle valve'------ then Vp44.
 branched off at the 'T' and needle valve-------5 feet of line-------then the electronic sensor.
Edited by JAG1
On 2/10/2019 at 4:13 PM, mcknight77 said:
I'm dense some times but I believe I understand how this plumbed now. Looks like I can get the fittings from Vulcan if I can't find them locally. What is a source for the needle valve?
Currently ACE hardware has them, I just bought one a few weeks ago. I can get you a P/N for it. NAPA doesn't carry them anymore, god knows why.
More progress. Yesterday we installed the relocation kit from Vulcan. Included t-fitting, needle valve, snubber, then rubber(?) line to the sensor. I opened the needle valve about a half a turn. Gauge is showing 15 psi and is steady idle to full boost. Still have to build a bracket to hold the sensor to the inner fender.
Another question: I have bypassed the factory filter and lift pump. I assume I can remove them from the truck?
Yes you can but the bracket for the lift pump has to stay. It covers a hoe in the block for the mechanical pump that ran the 12v trucks.
I dont see what lift pump you used to replace factory one. Since you bypassed the oe filter did you put something else in for filtration?
