Injectors/turbo
Sure it will work but there certainly are better options out there for turbos.  Towing with it will not be fun.  If you don't tow with it you'll probably be disappointed in the spool up for the size it is.  You'll smoke up the road a good bit before it lights.
I don't know your financial situation but I would only run it if it were given to me and didn't have any other options currently.  Otherwise I'm buying a 62/68/12 and getting the best of both worlds...spool up and power.
without the fueling control the quad offers he would be smokey, but the quad does a very good job at managing fueling.    I don't think smoke will be an issue.
the hx40 wouldn't be my first choice, but it does flow enough air to keep the 7 x .011's perfectly happy.
