Cruise, wiper solvent motor?
Wipers work fine, its the wiper solvent that doesn't work. Brand new motor, that works if you hot wire it so maybe the switch in the control knob because there is no power to the motor when you push the lever in.
What controls the cruise control then?
Depends.
Automatic transmission - The Steering wheel controls are received by the Central Timer then past on down the CCD Network to the PCM. Where the PCM talks to the ABS module to get road speed and then controls a vacuum motor pulling the throttle. This is because the throttle valve on the transmission needs to sense throttle position.
Manual Transmission - The Steering wheel controls are received by the Central Timer then past on down the CCD Network to the PCM. Where the PCM talks to the ABS module to get road speed and then controls the ECM directly. (Fly by wire).
As for wipers it could be the multi-function switch in the column is worn out.
