Block identification
Pictured is the block numbers I just installed in my truck.  I removed the infamous 53 block. After attempting to start with no luck.... I researched and found that the back of the cam gear with the newer block has a tone wheel where the original only had a notch.  I'm in the process of swapping the cams out because I'm sure this is the reason for the no start.  I would like to identify this block for future reference if anyone can help me out.  1998.5 ram 3500
