Boost PSI on iQuad
So I replaced the MAPS sensor and no change. At 5psi on manual gauge I show 1psi on the iQuad. I just bought the iQuad 2 months ago. I’m using the V2 1998-2002 version 2.7. Should I try the V2 Quadzilla Only it says version 3.94?
No,
The quadzilla reads map values from the ecm until 16 psi.  this is likely just the way your truck is some late trucks seem to have lazy map outputs from the ecm.  As long as map increases smoothly and is not jumpy then there is no issue.
